What do i need--amp kit?
Username: Nyyfan13
VA USA
Post Number: 518
i need an amp kit for my hifonics brutus amp, running 1200wrms at 1 ohm for my Fi SSD.
im getting one at either walmart or BB, maybe CC. what gauge wire do i need? i need all info so i can buy it tomorrow cause ima do the install later this week and wanna get everything together.
thanks
Username: Stnorris
Not yet decided, IA US
Post Number: 1509
i wouldnt go to any of those places. I dont think that bb cc or walmart even have big enough kits. Bb and walmart only carry 60a agu fuses at the biggest, not sure about cc.
I would definantly order from ebay. You can get a better amp kit for half the price than those stores. Its worht the wait of shipping.
Username: Grebnereon
Post Number: 383
well, first off, walmart wont have big enough wire for you.second, you will get totally ripped off at BB or CC. if they even have it
but you need:
1/0 gauge power wire. like 18 ft.
remote turn on wire
RCA interconnects
fuse block + fuse(probly about 150Amp fuse)
2 1/0 gauge connecters (1 to hook to ur battery and i to hook your ground to)
Post Number: 384
DO WHAT STEVE SAYS!!! better stuff on ebay, at a cheaper price. i think you can get a buy it now stinger kit on there for about $70, its from a store thats located in southern Indiana, they ship out first business day cause i looked into getting the exact same thing.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3624
http://cgi.ebay.com/KnuKonceptz-Blue-Pearl-4-Gauge-Complete-Amp-Kit_W0QQitemZ220 041802069QQihZ012QQcategoryZ71528QQcmdZViewItem
this would be a great match for that amp.
good wire and RCA's.
Username: Stnorris
Post Number: 1514
HOLY SH*IT^^^! that is so cheap, and reallly nice. wow. i bought like 20ft eko 4gauge for like 22 bucks awhile ago off ebay. haha i should have just gotten that instead.
Username: J_baby15
Kentucky
Post Number: 726
hey steven the walmart here carreies a 1/0ga fused distrobution block. THey jus got em in, it goes from 1/0 to 2 4ga. and has 2 100a fuses included for only $12 i think. Biggest wire they got is 5ga tho...not even 4 :P
Username: Stnorris
Post Number: 1517
hmm. not bad. so they got the distribution block, but no wire for it? lol.
Username: Riskyb
Post Number: 327
Yea my walmart carries some schoshe stuff. But yea the biggest fuses they have are 100amp. I saw a nice batterey terminal in there for 7$ i need to buy. Much better than my ring terminal ghetto thing lol.
Username: Nyyfan13
VA USA
Post Number: 519
alrite thanks, i guess ill just use ebay then
Username: Nyyfan13
VA USA
Post Number: 520
so this will work good with my set-up?
Username: Nyyfan13
VA USA
Post Number: 522
bump...
Post Number: 3644
yes.
Username: Nyyfan13
VA USA
Post Number: 523
ok thanks marshall, and im sorry i had to ask teh same question twice, i just didnt want to buy something that is wrong.
