Fi BTL, Q or SSD??????????????
Username: Avirex64
Vallejo, CA United States
Post Number: 74
I am looking to get 2 15's. Which do you guys prefer? Need somethin that will blow my trunk off!!!!! Also what kind of amp to push it? I heard kicker was good with FI's, what do you guys think????
Username: Avirex64
Post Number: 75
Or maybe 2 mags????? I need some opinions!
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1394
Depends on your budget.. Two BTLs would be your best bet given you have enough money to send them 2000rms .. this includes amp(s) and eletrical upgrades. The cheaper route would be just to get two Fi SSDs with a Hifonics BXi 2006D
The amp is rated for 2000rms x 1 @ 1 ohm so you would need two DVC 4 ohm subs and wire them parallel. The amp is over-rated so each sub should be at least seeing their RMS rating if not a little more.
Username: Frkkevin
Post Number: 1395
SI Mags are great subs and get loud while sounding good... like I've said.. depends on how much your willing to spend for eletrical upgrades and amps..
Username: Avirex64
Post Number: 76
What electical upgrades do you think i will need? Yes I might go with the 2 SSDs. Those will hit hard right? Ive never actually heard the subs, just heard people talkin about them
Username: Avirex64
Post Number: 77
arent the SSDs only 2 ohm subs tho?
Username: Tremor1127
Post Number: 358
they will rip you apart...
Username: Avirex64
Post Number: 78
haha just what im lookin for. they are only 2 ohm tho right?
Username: Frkkevin
Post Number: 1396
My bad.. you can get DVC 1-2ohm coils with the SSDs.. so get the Dual 1 ohm coils.. wire the subs in series for a 2ohm load each then wire them together parallel to the amp for a 1 ohm load.. either or get the dvc 2 ohm and find a amp that does around 1600rms at 2 ohm. Kicker will have you covered if you go that route.
If you run with just two SSDs the only eletrical upgrades needed would be the Big Three and I'd suggest using 1/0gauge wiring. With more power you'd be setting yourself up for a H/O alternator. That would be nice to have with just 1600rms but you can manage with the Big Three, 1/0 guage wiring, and a good healthy alt/batt.
Username: Avirex64
Post Number: 79
the big three? what is that? also how do I hook them up in series then parallel? sorry im still a beginner
Username: Dustin3
Tigard, OR U.S.
Post Number: 3925
www.the12volt.com --- woofer wiring
basically, series/paralel wireing is just diff ways to wire a sub so that it presents a certain impedience load on the amplifier. you need to take into account the VC's and ohm of the sub and what it can wire to...
the big 3 upgrade is a electrical upgrade. It changin out the wires from:
battery + to alt
Battery to ground
alt to ground
and you usually use around a 4 awg wires to do this or bigger depending on the current u will be runnin through them
Username: Avirex64
Post Number: 83
oh ok, can I do that myself? Which do you think is better, running them at a 1 ohm load with a hifonics amp or a 2 ohm load with a kicker amp?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3928
really doesnt matter. which every load that the amp can take in reference to the subs you get.. voice coils it has and the ohm of the sub. kicker amps are alot higher quality than a hifo amp
and yes, you could prolly do the big 3 urself :-)
Username: Avirex64
Post Number: 87
ok so you think i should go with the kicker amp and the 2 ohm load? U think the Kicker ZX1500.1 will do the job at a 2 ohm load?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3931
of course it will. if the amp is rated ay that load it will perform well at that load.
if you were getttin the zx1500 amp you need to make sure you get the Dual voice coil, 2 ohm subs
Username: Avirex64
Post Number: 89
ok, cool thanks for all tha help
Username: Bass__monkey
Las Vegas, Nevada U.S. of A.
Post Number: 169
kicker kx 2500d is one of the most efficient amps on the market today... try it with 2 ssd's with the copper coil. YOU WILL BE IMPRESSED! (copper coils on these subs sound GREAT!)
Username: Avirex64
Post Number: 90
that wont over power them?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3939
it will be overpowering them. i wuld stay with with zx1500. i think thats what he meant to say.. i shot you a reply back J
Post Number: 184
thanks bassman3... but if u wanna feel power for short term try it out. it gets pretty intense. i abuse my stuff daily and have no problems but that is experience. the ssd's are a little underrated... more like 1000 rms in my opinion. it's all about the application and im an abusive basshead... i just try to HELP and yes somtimes i get out of hand, lmao! for example, i throw 2500 watts to a q and it takes it! but when u think about it, it's abuse to the sub, system, and ur ears. im surprised im not deaf yet, but i play with stuff any time i have uhhhh.....TIME. lol! the instant u smell somthing funny, in my case burnt adhesive on the voice coil, i turn it down and play a bass track below tuning to flop the subs around... they get the most cooling in that mode, then i rest it for 15-30 mins... then again i let er rip! have fun! DIYers rule!
Username: Avirex64
Post Number: 91
2500 watts to 1 sub?????? thats crazy
Username: Basshead86
Try Google
Post Number: 7779
so is he:-)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3157
you're going to blow your head! lol!
BTLUSA
Post Number: 6604
i am thinking of putting 4 kicker kx2500.1 on my 2 btl 15s. 10,000wrms would be a killer. MUHAHAHAHAHAHA.
Username: Adddisorder
West palm, Florida
Post Number: 1525
definatly do that chad it will be insaneeeee
Username: Juliob
Post Number: 3164
Chad.... WTF do you smoke? lol!!!
That would be sweet, why don't you go to a TL and tell us how many DBs are you hitting???
Post Number: 242
im not crazy! i've put 1 12" ssd to 2400 watts and it holds up... give or take "5-10 mins will give u a smelly coil" so just turn it down it'll be fine.(dependant on application) just don't be a total nincompoop and fry it...(voids warranty) oh... never ever play below tuning at those power levels. :-) yii haaa! bass headz!
Try Google
Post Number: 7861
lmao, haven't heard that one in a while.
Username: Avirex64
Post Number: 100
which do you think will hit harder? 2 15'' Q's or 2 15'' SSDs?
Try Google
Post Number: 7881
2 Q's. that's easy. lol
http://forum.realmofexcursion.com/forumdisplay.php?s=8f4586720c9bacc6ba87dcd5284 11b92&f=58
Username: Avirex64
Post Number: 101
what would be a good amp to push 2 15'' Q's????
Try Google
Post Number: 7886
a Hifonics bxi2026 err w/e you call it..it is underrated though
or a ZX1500.1
or if you have some CASH an Orion 2500d
Try Google
Post Number: 7887
overrated. my bad
Username: Avirex64
Post Number: 102
both of those will be underpowering them right?
Username: Avirex64
Post Number: 103
http://cgi.ebay.com/Orion-West-Coast-Customs-WCC-D5000-Amp-Amplifier-2500d_W0QQi temZ300042333943QQihZ020QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This will push em right?
Try Google
Post Number: 7890
yes.:-)
Username: Avirex64
Post Number: 112
it wont over power them?
Username: Drsmith
Montana USA
Post Number: 1559
no the 12 challenge said anything under 1800 i think is fine
