Wiring problem
Username: Claytonk
Carlsbad, CA USA
Post Number: 42
could anyone tell me where to find the vehicle speed sensor wire and/or the reverse gear signal wire in a new gto. thanks
Username: Tjmutlow
Post Number: 3087
PONTIAC, GTO, 2006, Speed Sense
The ECM (Engine Control Module) is on the driver side fender, under the coolant reservoir.
The VSS wire is also in the driver kick, in a plug above the PIM (Powertrain Interface Module), in pin 3.
close
Speed Sense purple/white ac ECM, blue plug, pin 21
