Kicker cvx/l7
Username: Kwrubel21
Shelby Township, MI United States
Post Number: 251
so i hear the cvx is just the round version of the l7.
so i guess i'm asking, which sub would you guys suggest??
Username: J_baby15
Kentucky
Post Number: 709
I would go CVX. L7s are poorly built. I've owned a 15L7 and was actually more impressed with the CVRs, havent heard CVXs tho.
Username: Kwrubel21
Post Number: 252
i saw the cvx's today. i guess it's built with the same motor and magnet. but it's round instead.
Username: J_baby15
Kentucky
Post Number: 711
Exactly. Definately a better choice. Should get close to as loud, and sound alot better.
Username: Adddisorder
West palm, Florida
Post Number: 1508
iv heard the cvx and they arnt bad at all. only kicker sub i would go with actually
Username: Kwrubel21
Post Number: 253
would you guys go ported on a cvx or sealed?
Username: J_baby15
Kentucky
Post Number: 714
Definately ported, tune to like 35hz and you should be happy. What all do you hav in mind for this set upa nd how much room u got?
Username: Naledge503
Portland, Oregon U.S.
Post Number: 430
I got my cvx 12's ported to 34hz and i like'em alot.
Username: Logan__tille
AudioqueUSA
Post Number: 2058
^what happened to your SD2.5s?
Post Number: 431
I'm waitin to get a custom box them
Post Number: 432
I'm gettin it made to DJ's spec's. The other box i tried them in was too small and tuned too low.
AudioqueUSA
Post Number: 2059
oh ok, they should pound now.
Username: Kwrubel21
Post Number: 254
i don't have much room and my truck is in the shop right now from getting the window blown out.
but once it's back i'll take measurements.
if i go cvx's i'm going to put them all in a big ported box. 2.5cuft chambers ported to 33-35hz.
the guy at my local audio store said in order to make them fit you would have to have two firing at the ceiling and one on each side angled at about fourty five half way between the ceiling and doors. anyone want to help me design this box??
Username: J_baby15
Kentucky
Post Number: 716
im guessin you hav and extended cab? I'll help you out if you can show me some measurements.
Username: Kwrubel21
Post Number: 255
i have a few measurements right now if you want.
i'm going to put in a false floor due to a little hump at the back of the truck. i want the box to be no more than 16 inches deep(from front of ext cab to the rear windshield). and each chamber no more than 14 inches wide. so we're looking at about 59.75 inches long including all four chambers and .75in mdf seperating the chambers.
now the height should be what we have as a variable for our port and whatever. but i'll let you know exactly how much we have to work with on monday.
