Orion 2500D VS JL 1000/1 @ 4Ohm
Username: Havok13154
Poway san diego, Ca USA
Post Number: 35
The Orion does 1200@4Ohm the JL does 1000@4Ohm. witch do you think is better? the sub is a SI D2 Mag 15"
money doesn't matter as i can get them for about the same price.
what the the THD % of them at 4ohm?
Why did you pick one over the other?
Username: Tjmutlow
Post Number: 3107
the orion maunaul saysless then 1% thd at 4 ohms, the jl is .05%@ 4 ohms, i know th orion is a power hungry amp, it needs alot of power, so if your not upgrading electrical, i would stay with the JL
Username: James1115
Ct
Post Number: 7170
the orion wouold be nice if you ever plan opn running another one you have the headroom, but if you are talking who has better build quality? JL all the way.
Fi AudioBTL
Post Number: 6669
jl all the way for me too.
i used to own a couple of jl 1000/1 and now i own a couple of orion 2500d. they are both good amps and are very reliable but the jl just seem to have a better built.
Post Number: 36
i have a kenick 1800, 1950 cold cracking amps in the trunk that is all i got.
i don't think I'll be adding any other subs. I might redo what i have already into a CRAZY custom fiberglass box
Username: Jblanford
Post Number: 54
Chad do you have any 2500's you want to sell?
Username: James1115
Ct
Post Number: 7171
I would go with the JL:-)
Fi AudioBTL
Post Number: 6721
maybe later joe. like in a month or two. when i decide to upgrade to the 4000wrms memphis amps.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3190
damn chad, you're a setup h0e
Username: Ote888
Philippines
Post Number: 10
i would go with the JL too... i used JL in my 3 13w7s
Username: Slamminsystem05
Raymond, MS United States
Post Number: 11
JL is wayyyyy better quality than the orion. stay with JL brotha...
