Strapping amps.
Username: Mr_kebo
Albertville, Al USA
Post Number: 685
When strapping amps do you have to set the gains on both amps or just one?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3611
depends on what type of 'strapping' you are talking about.
amps like orion 1200d's---you just set one amp to master and one to slave...then set the gain and other setting on the master amp.
Username: Mr_kebo
Albertville, Al USA
Post Number: 687
well its the 9.1 amps from eD
Post Number: 3612
the nine.1's have master/slave.
Username: Mr_kebo
Albertville, Al USA
Post Number: 688
ok. A guy on the eD forums just told me i could expect 3500 from the strapped pair easily. How will the 15"HD3 take that daily? Would i be better off with a 15" loaded BTL
Username: Bsman
Sarnia, Ontario Canada
Post Number: 48
how do you strap and amp?
Username: Bsman
Post Number: 49
how do you strap two amps?
Username: Mr_kebo
Albertville, Al USA
Post Number: 689
The manual that comes with the amps will show you how to wire it up. Im sure marshall can chime in and tell exactly how.
Username: Bsman
Post Number: 54
haha i wish he would sometime this year:-) jj but anytime now.... haha
Username: Bsman
Post Number: 55
bump
Post Number: 3614
w/ alot of amp...this is how you strap them:
-run a mono RCA from one amp to the other
-you set one amp to master, one to slave.
-run the + speaker terminals on the master amp to the + terminals on the sub.
-run the + terminals on the slave amp to the - terminals on the sub
-run a jumper from the master's - terminal to the slaves - terminal.
the master amp will act like your pos. voltage rail, and the slave amp will act like your neg. voltage rail.
Post Number: 3615
if you get 3500w out of those amps...i will be stunned.
i HIGHLY doubt they will give you that much power.
3000w...maybe.
Username: J_baby15
Kentucky
Post Number: 685
Marshall check ur email if you can.
can an orion 2500d be strapped with another?
Post Number: 3616
no...the 2500d and the new d5000's are not strappable.
Username: Mr_kebo
Albertville, Al USA
Post Number: 692
*QUOTE*
at 1 ohm... you had better have a very solid source of voltage for them... but figure around 3000-3500+
in an extreme case, with the ams pushed way too hard (and with waaaay too little battery source for the application) i managed to get 4500 from a pair....
Username: Cenus
4, 20
Post Number: 2417
4500wrms from a pair of strapped 9.1's BS, theres no way unless that was 18volts at 50%thd.
Username: Mr_kebo
Albertville, Al USA
Post Number: 698
They benchmark the 9.1@1ohm doing 1850 watts. still dont beleive that guy getting 4500 from a strapped pair.
Username: Basshead86
Try Google
Post Number: 7759
that is probably my favorite car audio term.
Master/slave. :-)
when you say that in front of somebody who doesn't know what you are talking about, they will give you that thousand-yard stare until you explain it to them. hahahahahahaha
