What size wire and where should i get it from
Username: Xstokes88
San Antonio, Texas United states
Post Number: 120
ive been away from here for a while and finally got time to work on my system again..all my money has been goin into my car..but yea i have 2 L7s and a 1500rms rf x7 amp..what guage wire should i use and where should i get it from? thanks for any help..o yea im tryn to find a place that ships fast or a place that sells it here n san antonio..so i can get it in there within the next week or so..thanks
Username: Grebnereon
Post Number: 352
0/1 gauge.... http://www.elementaldesigns.com/
i think you can get it for like $2 a foot...which is pretty cheap these days
Post Number: 353
http://www.edesignaudio.com/edv2/index.php?cPath=1_54_55
there it is for 2.50, or you could get it here for 3
http://store.realmofexcursion.com/
Username: Xstokes88
Post Number: 121
o ok..thanks..im lookin for an entire amp kit..i didnt kno they were that much lol..
Username: Adddisorder
West palm, Florida
Post Number: 1493
knukonceptz.com get the klm 1/0 only 1.75 a foot
Post Number: 356
get one off of ebay...
or maybe on of the sites i just listed
and dealers are way too expensive, theyll charge you $6 a foot for 1/0 gauge.
there is one at Realmofexcursion.com for $90 and its Kicker
Post Number: 357
if you want a good, quality amp kit, youll pay big $$$$$$$ for it.
you can get like Absolute amp kits for cheaper but you have to watch them off brands, some use cheap copper or sometimes not 100% copper, and some 1/0 gauge is more like 2 gauge cause they go cheap ...also good wire will have a high strand count so that it is not as stiff, cause 1/0 is big stuff and isnt very flexible
Username: Xstokes88
Post Number: 122
yea i kno we work wit it at school..im my dc ac class but i might just have to see if i can pick sum up there. thanks tho.
