Archive through October 24, 2006
Username: Croneal1986
Laurinburg, NC
Mike,
I have a 98 ford explorer xlt and i need some serious help trying to hook up the cd player, have a amp and sub hooked up just need to know how to match my cd player wires to the factory wires, my cd player has a blue/white, yellow, black, red, black/purple, white, white/black, grey, green, grey/black, purple, and a green/black. please help me to match up. thanks
Username: Leew
Ketchikan, ALASKA USA
Post Number: 593
for Colby O'Neal:
application/x-zip-compressedUpload
Ford Explo.1998 Radio with Sub.zip (60.9 k)
Username: Abwhite86
can i get awiring diagram for a pioneer p6400 i already got the stock diagram for my 96 jeep cherokee sport
Username: Theherm11706
Do you have a color diagram for a 1990 honda civic hatchback?
Username: Abwhite86
look on the top of your stock stereo for the wiring diagram
Username: Brett_498
Mikado , MI USA
i need OEM wire diagram for a 1991 dodge shadow? please
Username: Maresgreg
Hello All,
I need a wiring diagram for 1990 ford mustang LX. The person before me cut the connectors so I am down to colored wires. Please help. :-)
Thanks,
Greg
Username: Leew
Post Number: 594
for Greg and his baby:
ford mustang 1990.zip (37.1 k)
Username: Leew
Post Number: 595
for brett and his baby:
1991 dodge shadow.zip (39.5 k)
Username: Leew
Post Number: 597
Sorry Joseph Herrmann, for 1990 honda civic hatchback I have nothing
Username: Maresgreg
Thanks a million Mike!
Username: Jeepdave
I am looking for the wiring diagram for a 1992 Jeep Cherokee. Four speakers. Thanks.
Username: Leew
Post Number: 598
David,4 speakers and 6 speakers,its the same wiring :
1992 Jeep Cherokee.zip (38.9 k)
P.S.on speakers: wire A= Plus, wire B= Minus
Username: Maresgreg
Hey Mike,
Another question. I believe I have it right. But I connect the yellow from the radio (contant) to the Yellow/Green on my car, the red (radio) to the yellow/black (car), and black (radio) to the to the red (car) or to a new ground correct?
Thanks!
Username: Leew
Post Number: 600
well Greg:
if your yellow from radio Constant(aka Batt/Memory) you have to connect to the LT GRN/YEL.
The red one form radio to the YEL/BLK.
and ground Black from radio to the Red or BLK/LT GRN.
yes its correct.dont worry be happy!
Username: Bates44
Sewell, Nj United States
i need help. the original stereo harness in my jeep was cut. i need help trying to figure out what color wires do what in a 1994 jeep cherokee sport. 4 original speakers.
Username: Leew
Post Number: 601
for Brian E Bates
jeep ch.1994 radio.zip (52.0 k)
Username: Bates44
mike,
thank you very much. i have gone through 3 head units thinking they were faulty. they probably weren't. you just saved me over a hundred bucks. appreciate it.
thank you,
brian bates
Username: Leew
Post Number: 603
no problem Brian E Bates,any time!
Username: Maresgreg
All works great. Thanks Mike!
Username: Leew
Post Number: 604
Alright Greg!no problem!
Username: Jmaruca
Rancho Cordova, CA USA
Hi all. I hooked up a Jensen to my 1995 Honda Accord using Mike W Lee postd (thanks, Mike!). Stil, it has power but absolutely no sound and no display lighting on the Jensen unit.
There is only one wire that I don't where where to connect in the Jensen. It's the red/black one that the diagram says is for illumination. There's no where to hook it on the Jensen stero unit. Is this the reason why there's no display on the Jensen? Any help at all would be appreciated!
Username: Kristoffer209
Mike W Lee can you help me out with the stock radio wiring codes for a 99 Honda Civic. Thank You.
Username: Leew
Post Number: 606
Kris,please read inside the txt.file
honda civic 1999 LX Radio.zip (32.5 k)
Thanks Mike I've been looking every where for that diagram. Seems like you have all of the car radio answers. Thanks again.
Username: Pagnotti
Harveys lake, Pa Us
need wire diagram for 94 lincoln continental with jbl system in it.
Username: Leew
Post Number: 608
for joseph pagnotti:
Linco.Cont JBL radio.zip (58.0 k)
Username: Dagedetter
Grand Island , Nebraska United States
i need help with the wirirng of a 2000 dodge durango. like what color wires goes where, and if i can hook up my steering wheel remote to my aftermarket cd player........please help...thanks
dage
Username: Blown67
I just installed an AIWA CDC-X207 in my 83 jeep cj7, Everything works great except the display isnt lighting up, the text is but it is supposed to be an illuminated blue. I have 2 wires I can still connect, both orange, 1 is marked dimmer and other is marked illumination positve, any idea what to tap into for these, dash panel lighting? Thanks
Username: Scott_allen
I have a 2001 Chevy Cavalier and I'm trying to hook up a CD player. My wires are cut and I'm in need of a diagram. Any help would be greatly appreciated. Thanks!
-Scott
Username: Cozza171
hi i have a nissan skyline silhouette 1987 model care and im trying to connect a kenwood head unit, the wires with the head unit are labled but i dont know what to match them up 2, does any one have a diagrame of what wires in the car are?
Username: Airborne2182
i have a 2002 Jeep Grand Cherokee Laredo w/o Premium sound. If some one can please let me know what the wiring diagram is
Username: Monophobia
Greenford, Middlesex United Kingdom
I have just replaced the standard cassette/radio and speakers of my Ford Ka (2000) with a Panasonic MP3 CD player and Sony 3-way speakers using wiring adaptors with limited success. Everything works fine, but I lose all my radio and EQ settings whenever the vehicle is switched off for more than a few minutes. I am guessing that this is due to a wiring problem or that the stereo needs to be directly connected to the battery, but what do I know? If it is a wiring problem could anyone give me a diagram of what should go where?
Username: Gary_alan
Howell , Mi
I'm looking for a wiring diagram for the radio and rear control unit for a 2004 Ford Taurus SE.The unit in the trunk was altered before I bought it and its a mess!
Username: Green3
Monticello, GA USA
Hello. I am looking for the radio wiring diagram for a 1988 Ford Escort Wagon. Bought a hook-up kit, but don't know what to match up. Thanks.
Username: Leew
Post Number: 612
Cynthia Stewart
This is with out oem Amp:
ford escort 1988 radio.zip (14.7 k)
Username: Green3
Monticello, GA USA
Thanks Mike! My daughter will be excited...4 hour road trip!
Username: Dschave
Need a wiring diagram for a 2001 Toyota Camry with the JBL system. 1 connector. 20 pin. I think there are only about 12 wires active. Trying to get this thing finished today.
Thanks in advance
Username: Trs
Guelph, On Canada
I have 1994 Altima - I have 2 red/yellow wires and 2 red/blue wires that were attached to my stero wire harness that I'm not sure what to connect them to. If I attach the red yellow wires to a ground all my dash lights work properly, if I attach them to power they just stay on allways. The red/blue wires also stay on allways if attached to power but blow a fuse if attached to ground. Do I need these wires (red/blue)hooked up? Also should the red/yellow wires be grounded? Please help!!!!
Username: Leew
Post Number: 614
Cynthia I am happy...any time!
Username: Leew
Post Number: 615
Danny Schave try this:
2001 Camry radio JBL.zip (34.7 k)
Username: Leew
Post Number: 616
Todd Schell ,those wires for light system,this is for ya:
1994 Nis. Altima base radio.zip (30.5 k)
Username: Trs
Guelph, On Canada
Thank you so much Mike, But I still have a problem, I don't quite understand the diagrams that you sent me. The wire harness has been removed from the vehicle by the previous owner and the stero that I'm installing doesn't have these wires on it's harness for me to connect to. So my dilema is I need to know what to do with these wires. If you have any further info. that would be great!!! Thanks again for all the help so far.
Username: Wbstein
I need a wiring diagram for a 1997 Lincoln Continental with JBL (premium) sound.
THANKS!
Username: Dasupertech
I Need a Wire diagram for a 2002 Chevy Suburban with onstar, I dont have a Bose System. I need to be able to find the front and read speakers outputs from the head unit. I would also like to know if there is a wire i can use as a remote Amp turn on?
Username: Jenifer_contreras
Tampa, Florida USA
Post Number: 218
check this out:
2002 chevy sub.base radio.zip (17.3 k)
Tampa, Florida USA
Post Number: 219
you can use ignition wire or any of ACC.
I think I found a wire that use to go to the Aux Tape deck in the console that has a 12 volt source when ever the Deck is on.
My Suburban also has the stock 8" sub is there a wiring diagram for it?
Jenifer some of the wire colors match up but a few others Do not...Is it safe to say that those numbers are the correct ones? Thanks for the quick replys
Tampa, Florida USA
Post Number: 220
give(if you can)wires color from your system,so can compare to my diagrams.I saw there is four kinds !of the radios in this GM
Tampa, Florida USA
Post Number: 221
from your car,I meaned...or count,how many wires in plug!
1. Baby Blue
2. Lt. Brown
3. Lt. green
4. Lt. green
5. Black
6. Dark Brown
7. Gray
8. Orange
9. Dark Green
10. Orange
11.Purple
12. Black with White Stripe
13. Blue
14. No Wire
15. Green
16. Green
17. black
18. Blue
19. Dark brown
20. Dark Brown
I got the numbering off the back of the unit
Username: Latigerlily
Does anyone have wiring color codes for a 2002 Mustang Convertible?
(In an attempt to be a good newb I did a search and didn't find a previous posting of this particular request)
Thanks in advance!
Tampa, Florida USA
Post Number: 231
Jamie,you got a nice system:
2002 sub chevy with rear cotrol.zip (89.0 k)
Jenifer you are Awesome!!!!!!!!! Thanks very much!!!!!!!!!!!!!!!
Username: Rick_t_c
I just bought a 2006 GMC Canyon and wanted to upgrade the stereo. All the autoparts stores say the harness is not available yet, too new. Would you have a wiring diagram for it? It is standard cab, 2 speakers.
Username: Virtthemaest
Does anyone have the wiring diagrams for a 1995 Ford EF Falcon?
I have timelessly been trying to install a new CD player because the stock standard Ford cassette radio says "err" but I cannot figure out the wiring for the life of me! I have tried every combination but been so unsuccessful. If I can download the manuals car cassette radio wiring diagrams it will help me heaps, as I'm banging my head against a wall here.
Even if I took a photo of the stereo wiring will that help?
Regards,
Virt
Username: Sandmanxx
Grover, NC
Hello. Looks like this is the place for a wiring diagram inquiry. I'm looking for the car side diagram of a 2001 Chevy cavalier, base model, with the factory cd player. I purchased one of the harness converters for the GM, but no go. Some of the harness connectors wires are offset from the car's wiring. The car's plug has 2 rows of 12 pins, female, and the radio has the male pins in the square plug hole. Thanks for any help! Any other info needed, please ask.
Warren
Username: Djformi
Columbia, Maryland USA
Curious if any of you could help me find out where the speed sense/speed signal inoput wire is on a 2001 ford econoline. Also need the reverse gear input. We are trying to install a AVIC-D2 in our office mobile van and this is stumping us. Any help is appreicated thanks
Dan
Username: Leew
Post Number: 625
Daniel J,take a look at this diagram and find VSS INPUT...this is speed wire...
the reverse gear input wire...take it from tail light,reverse light..
2001 ford econo.zip (8.1 k)
Username: Djformi
thanks so much
Username: Am862004
1997 Ford Thunderbird Wiring Diagram???
Username: Noviceinstaller
Here, There
Post Number: 76
Amy:
http://installdr.com/Harnesses/Ford-Wiring.pdf
Username: Fyau
Sydney, NSW Australia
I bought a Ford OEM CD6 MP3 player as shown and the model number is 5C2T-18C815-AC. It has got 2 connectors at the back, 1 at 20-pin and 1 at 16-pin. There is no schematics and operation manual. Could you please help? Upload
Username: Galen
Bay city , Tx United states
Post Number: 9
i hooked up a stereo in my friend's 01 cavalier and then someone broke into it and cut all of the wires. I know how to hook up the speakers but i am not sure how to hook up the other ones, can anyone give me some help.
Username: Galen
Post Number: 10
can someone give me some direction on where i need to go to get this information?
Username: M_anderson09
Greybull, Wy USA
Wiring Diagram for 1999 Chevy Suburban Radio.. Please!
Username: Leew
Post Number: 640
need more info about your car...oem amp,cd,sub...???
Username: N_a_t_h_a_n
I have just bought a sony xplod head deck and some new 4 inch speakers to put into my ford laser (1988 model) I got the speakers in fine, but need the wiring diagram for the head deck. Can anyone help me??
Username: Leperking
Wiring colour codes for a Mercedes-Benz CLK 200 (Year 2000) please!
I have that..
Speed = ?
Diag = Green and Brown
Mute = ?
+12V = Red and Blue
Antenna = White and Blue
Lights = ?
Ignition = ?
Ground = Brown
Thanks,
LK.
Username: Mrendas
I have a 1998 Cavalier Z24 2.4L and im looking for a wiring diagram for the stereo.
Thanks,
Matt
Username: Engrsapper42
Buffalo, NY
I have a question about a 2001 ford taurus radio. Im trying to hook up an amplifier and sub woofer but I dont know where to connect the remote wire. I want the amp to turn on with the factory radio but I dont know the pin diagram for the radio unit in the trunk. I appreciate any suggestions. Thanks
Username: Skippy1895
I'm installing an aftermarket cd player in my cousin's 97' Ford Taurus and I need help with the wiring. I need the color codes for the wiring on the factory side of the harness. I have the faceplate kit installed and connected all of climate control knobs and wires but I can't figure out the radios wires. Any help is greatly appreciated.
Username: Admir814
Erie, Pa Usa
what color wire do i need to connect for the remote wire my system has on an 06 ford focus?
Username: Rynes
Hello , I need major help trying to find out the wire colors for a 1992 mercury topaz audio system, Their is two connectors ) one is black and one is Gray) and i just need to know each wire( what it is) thank you for your time.
Username: Killyx
hey i saw you had 2001 camry but i don't know if its the same wiring i need wiring for Toyota Camry 1998 LE thanks!
Username: Twotimesthedimes
Neenah, Wisconsin United State...
Hey Mike, can you figure this one out? 1995 Ford Mustang, non-GT, V6, with Mach 460 stereo. I wired in a JVC I think and it's all working fine, except if you turn the key to the accessory position, let it sit for a bit, then start it, it makes a really loud popping noise. I heard that Ford factory amps take a 5 volt turn on lead and the CD player I know is putting out 12. Is there a way I could wire in a resistor to stop this? If so, what size resistor and what wire? Thanks.
Also, do you have a diagram of a Sony/JVC harness. I have one that came in my JVC in my truck and the wires are in the wrong spots. My back speakers are my fronts and a bunch are screwed up. I just need to see which pins are for what speakers.
Username: Scary_man
i need a color stero diagram for a 89 chevy cavalier.
thanks in advance!
Username: Psu711
I need a stereo diagram for a '02 maxima with bose.
My pioneer HU was stolen and I would like to put the factory 6 disc bose back in. I have found some wire diagrams but they dont seem to match. I also have a grey wire with white stripes that i cant find what it is anywhere.
Here is a post of one of the wiring diagrams i saw.
http://forums.nicoclub.com/zerothread/157919
notice no mention of the silver(or grey)/white wire
its 5th gen ('02) maxima with bose.
thanks
Username: Tort
Post Number: 66
Hey, Stephen R. Cole!you can get all electr.schemas for your Maxima 02-03 here:
http://www.jencyborg.com/Maxima/
Thanks to Jennifer Contreras!(This web-site belongs to her).
Username: Breakout
Phoenix, Arizona U.S.A
I followed a Googel link to this site looking for info on a VSS Circut on a 2.2L Chevy Corsica. I have the Chilton schematic but it's really vague. I need to know what it is, what it does and how to test/fix it. (Being able to find it would be nice also)
Username: 90gts
what about a 90 celica gts with factory amp and 10 speaker system?
Thanks for saving my from the headache i got trying this. And there is no grey wire for remote from factory
Username: Fyau
Hi, has anyone got the car-audio schematics for Toyota RAV4 3-door Edge 2002 model? Thanks.
Tampa, Florida USA
Post Number: 376
For you Freddy!
2002 Toy.Rav Radio.zip (16.6 k)
Username: Yesterdaysfuture
Houston, TX
2005 Ford Aviator wiring diagram needed help.
I've installed a 2005 Lincoln Aviator satellite ready head unit in a 2004 Ford Crown Vic and do not have lighted buttons or dimmer controls?
Tampa, Florida USA
Post Number: 378
this is ford crown vic:
this is lin.avia.
Houston, TX
Many thanks - I'll go check the voltages -
Username: Chuck07
anybody please have a 1991 dodge grand caravan wiring diagram with infinity premium sound. 4 of the 6 speakers have mini factory amps on them
Username: Jpodpora
Hey all! I was wondering if anybody could help me. I need a wiring diagram to find the Vehicle Speed Sensor (VSS) wire and reverse gear wire for a 2003 Nissan Altima 3.5SE. I see that jencyborg.com has them for the Maxima -- but I'm guessing the systems are different. (I'm doing a Pioneer AVIC-D2 intall...)
Tampa, Florida USA
Post Number: 379
Hey Jody! I have to know which radio you got?(base,bose or midline)!
Username: Jpodpora
Thanks for the quick response! Well -- I got the car used and I'm not 100% sure which radio it is. It's definitely NOT the Bose (there are no Bose labels anywhere). How can I tell the difference between "Base" and "Midline"?
Username: Zac_stashko
Hey can anyone tell me if the Panasonic Head Unit model number CQ-DF202 needs the illumination wire. I am hooking it up to a 1989 Ford Tarus and the 16 pin connector I have to go into my deck does not have the illumination wire in it (despite the packaging saying it should) but the dealer told me some models don't need the illumination wire. I hooked everything up last night without the illumination wire but had nothing on the screen and didn't hear any sound, didn't try to but in a cd though. If this head unit doesn't need an illumination wire can anyone else think what maybe my problem. Thanks
Tampa, Florida USA
Post Number: 381
Jody,go take schemas
http://www.jencyborg.com/Jody
the difference between "Base" , "Midline" and "Base"
As I see by the schemas:
The Boss system come out with OEM AMP and VSS signal.
The Midline come out only with VSS signal.
Base system come out ,let say "naked"
VSS signal(speed signal)needed for automatical audio volume control.More speeding= louder music (automatical)!
Let me know,if everything is alright!
Tampa, Florida USA
Post Number: 382
Jody actually,you got altima 3.5L it's top of the line.it's cannot be cheap radio there!
Tampa, Florida USA
Post Number: 383
Have to be Xenon light too!
Tampa, Florida USA
Post Number: 384
BTW. I included all schemas(the three radios and reversing)!
Username: Dch921
need wiring diagram for 96 explorer xlt with amp. Trying to wire the rear controls. Thanks
Username: Leperking
Bump...
I have that..
Speed = ?
Mute = ?
+12V = Red and Blue
Lights = ?
Ignition = ?
Ground = Brown
Thanks,
LK.
Username: Jpodpora
Hey Jenifer, sorry to bother you again -- but I was wondering...is "Joint Connector 3" (the block/box that magically splits the Front Right output of the stock headunit into Tweeter and Door Speaker outputs) an amplifier that would need to be bypassed for the headunit installation, or just a simple crossover?
