Ot: window tint question
Username: Oglejust
Il Us
Post Number: 255
ok 1st question.. i have the defroster in the rear window, the line ones. ive heard that you cant tint them because it will mess them up. is this true? 2nd question... what is the legal limit on tint? im looking into 2 1/2% limo tint. will this b legal?
Username: Naledge503
Portland, Oregon U.S.
Post Number: 411
legal limit is different from state to state.
Username: Oglejust
Il Us
Post Number: 256
well... im in IL if that helps.
Username: Ctmike
Ct.
Post Number: 2062
Windshield - Non-reflective tint is allowed on the top 6 inches of the windshield.
Front Side Windows - No tint can be applied legally to this window.
Back Side Windows - Any darkness can be used.
Rear Window - Any darkness can be used.
Username: Crayola0
Wisconsin
Post Number: 1294
were can u find this info
Username: Ctmike
Ct.
Post Number: 2064
The ST column is the STATE. The TYPE column refers to the VLT (visible light transmission) measuring method - through the tint itself (FILM) or through both the tint and the window glass (NET.) The WS column states the size tint allowed on the WINDSHEILD - usually stated as an inch measurement or "AS1" - which refers to the AS1 mark found on the windshield itself. It may also be a value as some states allow tinting of the entire front window. The FS column shows the VLT allowed for the FRONT SIDE windows. The RS column shows the VLT allowed for the REAR SIDE windows. The RW shows the VLT allowed for the REAR WINDOW.
The F.REF and R.REF columns refer to the allowed REFLECTIVITY of the front side and rear side glass respectively. (NR=not regulated. NE=not excessive (not specific.) NMMA=no metallic or mirrored appearance. MBNR=must be non-reflective (not specific.) MNIR=must not increase reflectivity. NR=not regulated. NONE=no reference to reflectivity in the current law.)
The R.CLR column refers to the colors of tint that are RESTRICTED or not allowed. (N/S=not specified. R=red. Y=yellow. A=amber. B=blue. G=gold. BK=black.)
Some states require a valid certificate to show the tint meets the law. Some states allow for tint outside the law for medical reasons. Also note that the values below are listed for cars - many states have dfferent values athat apply to trucks and SUVs.
Note that the information is current as of May 24, 2005 and is subject to change at any time without notice. Your current state law is the final authority, and you should refer to your local authorities if there are any questions.
ST TYPE WS FS RS RW F.REF R.REF R.CLR
AL NET 6" 32 32 32 20 20 N/S
AK NET 5" 70 40 40 NMMA NMMA R A Y
AZ NET AS1 33 ANY ANY 35 35 R A
AR NET 5" 25 25 10 NR NR N/S
CA NET 4" 70 ANY ANY MNIR MNIR R A B
CO NET 4" NO ANY ANY NMMA NMMA R A
CT NET AS1 35 35 ANY 21 27 N/S
DC NET 5"/AS1 70 50 50 N/S N/S N/S
DE NET AS1 70 ANY ANY NR NR N/S
FL NET AS1 28 15 15 25 35 ALL
GA NET 6" 32 32 32 20 20 R A
HI NET 4" 35 35 35 NR NR N/S
IA NET AS1 70 ANY ANY NE NE N/S
ID FILM AS1 35 20 35 35 35 N/S
IL NET 6" NO ANY ANY MBNR MBNR N/S
IN * AS1 30 30 30 25 25 N/S
KS NET AS1 35 35 35 MBNR MBNR R A Y
KY FILM AS1 35 18 18 25 25 N/S
LA NET AS1 40 25 12 20 20 N/S
MA NET 6" 35 35 35 35 35 N/S
ME FILM 4" 50 50 50 MBNR MBNR N/S
MD NET 5" 35 35 35 NONE NONE R A Y
MI NET 4" 4" ANY ANY 35 35 N/S
MN * NO 50 50 50 20 20 N/S
MO NET AS1 735 ANY ANY 35 35 N/S
MS NET AS1 35 35 35 20 20 N/S
MT FILM AS1 35 20 20 35 35 R A Y
NC NET AS1 35 35 35 20 20 R A Y
ND NET 70 50 ANY ANY NR NR N/S
NE FILM 5"/AS1 35 20 20 35 35 ***R A Y
NH NET 6" NO 35 35 NR NR N/S
NJ NET NO NO ANY ANY NMMA NMMA N/S
NM NET 5"/AS1 20 20 20 NONE NONE N/S
NV NET AS1 35 ANY ANY NONE NONE N/S
NY NET 6" 70 70 ANY NR NR N/S
OH NET 70 50 ANY ANY MNIR MNIR R Y
OK NET 5"/AS1 25 25 25 25 25 N/S
OR NET 6" 35 35 35 13 13 R A Y G BK
PA NET NO 70 70 70 NR NR N/S
RI NET AS1 70 70 70 NONE NONE N/S
SC NET AS1 27 27 27 MBNR MBNR R A Y
SD NET AS1 35 20 20 NR NR N/S
TN NET AS1 35 35 35 NR NR R A B
TX NET 5"/AS1 25 25 ANY 25 25 R A B
UT NET AS1 43 ANY ANY NMMA NMMA N/S
VT NET AS1 NO ANY ANY NR NR N/S
VA NET AS1 50 35 35 20 20 R A Y
WA FILM 6" 35 35 35 35 35 R A Y
WI NET AS1 50 35 35 MBNR MBNR N/S
WV NET 5" 35 35 35 20 20 R A Y
WY NET 5"/AS1 28 28 28 20 20 N/S
Username: Ctmike
Ct.
Post Number: 2065
^taken from http://www.stratusphere.net/tint.html
Username: Stnorris
Not yet decided, IA US
Post Number: 1493
front side windows in IA, and porbably illinois, is 35%.
Username: Stnorris
Post Number: 1495
lol i guess not
Username: Oglejust
Il Us
Post Number: 258
can i put the tint over the defroster lines in the back glass?
Username: Cashby
Post Number: 32
i live in iowa and actaully the legal limit is %70 which is hardly nothing! i have 35% and ive never been stopped or question..so i would say go 35% on the front windows u wont have any problems with police.
