Lil rob, or anyone with an explorer...
Username: Devastation101
Post Number: 139
what size speakers are in the rear of the Explorer? I was played a fool once when I bought my 6 1/2's for the front doors and realized that they were 6x9's! And I need to know a good set of 6x9's, tight budget, but still want some good quality!
Username: Renegadesrun
Lafayette, IN US
Post Number: 395
crutchfield
Username: Matt12490
The biggity biggity BAY, California USA
Post Number: 1386
i dont know about crutchfield. i had the same question as you except for my 99 acura tl and after i filled in the information to see "what fits my car" 5 1/4" speaks came up and 6 1/2". mostly 5 1/4" but still! they mixed them up so im still unsure.
Post Number: 140
Yea, Crutchfield is the reason I bought 6 1/2s for my front doors!
Lafayette, IN US
Post Number: 397
Mine was 5.25's.
I would never install a 6x9 in any hole.
I would do a bada55 6.5 set up front and 5.25's for rear fill.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 377
You could just make a baffle for the speaks and cut the door a little and put them in there
Username: Kickdoor
Post Number: 93
what kinda explorer you have? cause from 91-94 explorers take 5x7's im not sure of the 95 and p though....
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2160
its 6x8 in the 4 doors, but i made a bracket to hold 6.5 mid bass in the front doors. adn i have 6x8 in the back polk audio speakers, i got the 6x8 because i wanted the most midbass in the back. sound pretty good man.
get 6.5 speakers fro the front thats all that u need but if u have afew bucks get some polks 6x8 at crutchfield really cheap and worth the money
Username: Riskyb
Post Number: 264
Can anyone give me info or advice on putting your door speakers in boxes in the doors? door pods I think are what they are called?
I have been thinking of making my own.
Chicago, Ill Us
Post Number: 2163
u can make one of y our own with fiberglass and some bondo. but u can get them at crutchfield.com
Username: Bayrent88
Ingleside, Texas USA
Post Number: 70
my explorer is 6x9's both front and back...1999...at least i think they are...let me go measure
