What u know about gettin loud????
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2079
wat up people well i need to break the 150's this is my goal for this year no matter what it takes, i want mostly a sql set up, the subwoofer i want must be 1200-600 rms. here are some of my choices
2 15's fi q's
4 kickers l7's 12's (yes 4 even if they suck but they are good for spl )
1 18 btl fully loaded
1 audioque hd315 no make it 2
4 kickers cvx's
or 6 cvr's 12's
4 alpine type r's 12's
1 stereo integrity mg
well people its gonna be on the explorer subs up port back with flared ports the box it will be tuned at 35hz if its between 1-2 subs and 28-30 hz if its 4 or more subs.
remember that i only have 2000 rms at 1oh m to work with but i might get another 2k rms at 1 ohm in the future im open for suggestions too.
Chicago, Ill Us
Post Number: 2080
i think its gonna be LOUD!!!!
Chicago, Ill Us
Post Number: 2081
oht he 4 kickers l7's or cvx's make it 2 because they are gonna be underpowered so for me its better to be overpowered not bymuch than underpowered
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1976
imma have to go with the 4 kicker l7s 12's
if powered properly and in the right enclosure
those subs will hit 150dbs easily
ALTHOUGH i do not like these subs these are the easiest to hit 150 with especially with tht much
cone are it would be rediculous....
i think u should deaden ur roof lil rob..will help out the most
Chicago, Ill Us
Post Number: 2083
yeah im doin that too, im puttin the paint that spays rubber then a lil of dynamat original and for the final touch the foam from ed.
but yeah the kickers will be underated and i heard that kickers if they are not good powered they dont get that loud so make it 2 15's
Username: Jprix82
Post Number: 622
How much room you got in the explorer rob?
Username: Basshead86
Try Google
Post Number: 6986
why did you even bother putting the last choice. lol
1-1,000wRMS SQL woofer as opposed to ALL the other choices....
NO i am not singling out the Mag...i would have said the same thing if it was only 1 Q or Rl-P or Comp. lol
Chicago, Ill Us
Post Number: 2084
muddy i think the si mag only comes in dual 2 ohm i cant put two dual 2 ohm at 1 ohm man.
and i hear that the magcan break the 150's in a good set up plus the sub its expensive too
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1523
4 Elemental Designs 16Ov.2s. i have the exact box design, i can email you or whatnot if your interested. hits low/mid 150s in my mountaineer.
if you want more info AIM me jakeyplaysbass26
Username: Bigben
Post Number: 84
im kinda stealing your thread but how many db do you think 2 15" L7's with a zx1500.1 amp would hit? that is what i plan on getting so i was just wondering.
Post Number: 1977
2,369 dbs
its gonna be an insane setup man
Username: Bigben
Post Number: 85
be for real now. i would be dead if it hit that many db's and do you think it would break my windows or anything??
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3505
L5's are alil more efficient than L7's.
Try 4 L5's w/ ~2000wrms.
If all you want is loud...4 12" L5's and 2000wrms can get you to ~150dB if you know how to build a good SPL box.
In your vehicle...~10cuft net tuned to 40hz to start off...test and retune as needed (after testin, you will prolly end up w/ bout 43-44hz) tuning Subs up, port back. Line the back of the box up w/ those hooks on the floor of your explorer. It will prolly like to peak at ~48hz.
Username: Djl
Post Number: 7
Check our Jeremiah Ledgerwood's exployer.154.2 db drag Street C. USACI Street Beat 3 153.4 (30 seconds on music) Mecca AS3 2005 world Champ. Two AQHD315's
Username: Djl
Post Number: 8
Explorer,
Chicago, Ill Us
Post Number: 2085
jake man i dont have aim man but yeah im interested in the box design.
yeah im thinkin of gettin some kickers . yeah marshall thanks man ur the best i was tryin to make a crz box subs up ports back i was thinkin 29x29x19 4 four inch ports flared 12 each long each that should get me on the 150's im sure.
hey jake how much did u paid for all 4 woofers???
St. Louis, MO
Post Number: 1526
i paid 200 a sub.
Chicago, Ill Us
Post Number: 2086
sou paid 800 juzz for subs right??? do you have the box desing?? if u have it can u email it to me man i apreciated if u can.
extrmndor3@msn.com
Username: Van_man
Boston South, MA
Post Number: 1014
Hi Fi sound connection has NEW 15 L7 for $200 right now, if thats of any help.
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1767
i think you should get the HD3s
Username: Drsmith
Montana USA
Post Number: 1315
X 2
Username: Troy81
Tavernier, Fl Us
Post Number: 1233
4 18" ssx's and 4 orion 2500d's
Chicago, Ill Us
Post Number: 2091
troy i dont want to spend all that much, i was thinkin of spendin around 600 max for subs no amps
Username: Mschwitz
Milwaukee, Wi
Subs up, 4-4" Pnr ports to the rear. 4-12" L7 with 2000 watts you will do 150+ easy in an Explorer.
Username: Bernymac
Rialto, CA United States
Post Number: 433
You might also want to consider something that will last and you will be happy with in the end. You said you wanted some sq as well right so it'll be a sql setup. With a extra 150 you can get the hd315's.
Chicago, Ill Us
Post Number: 2094
wich ones are louder cvr's or type r;s???
Username: 420alldaylong
Post Number: 551
lilrob
What 2000 watt amp are you useing?
Chicago, Ill Us
Post Number: 2095
for testing a hifonics bxi2006 i juzz recently got it back from a shop they modded for me so it can handle .5 ohms fine and push close ot 3k rms at .5ohm pretty impressive, well with the modifications the birthsheet that they gave me said 2319 rms at 1 ohm at 14.5v pretty impressive theyjuz put bigger mosfets and bigger capaciotors. im gettin a kicker kx2055.1 on the future though
Chicago, Ill Us
Post Number: 2096
well i think im gonna have to go with 4 alpine type r's or 8 cvr's 12's yes 12 100=a pair at ebay
Username: Sploosh56
Ohio
Post Number: 1535
Get a pair of 15" Kicker Cvr's and throw 1500 rms to the pair
Build a solid ported box with the subs and port facing the rear. Tune the box to 37 hz and make sure each sub has about 4 cuft to work with.
Username: Night_mirage
AmmanJordan
Post Number: 536
lilrob , What u 're giving up with ATOMIC (LOUD) hehe
Ok why u don't think about DD's
two 2500 (DVC 4 ohm 600RMS , Can handle over 1500RMS each)
In DD's forum these is a guy who installs Z2( 6000@1ohm ) on 2515 . And he was tring to blow it . But he said it was very very clean and LOUD AS H!ll .
>>>DD>>>
I have one 2512 and zx1000.1
And i will buy another one powering by kx1200.1
AmmanJordan
Post Number: 537
or if u want u can get 9500 .
Just try DD's .. and u will never dispointed .
Username: Adddisorder
West palm, Florida
Post Number: 1201
i think the AQ hd3s 15s should be able to break 150 with 2k to the set. they are supposed to be really efficent plus the quality is better the kicker or alpine subs.
Chicago, Ill Us
Post Number: 2097
well man atomic its too expensive for me fakin dude raised the prices so no. those products kick @ss but now they are out of my range
if i get kickers i iwll get 8 or 6 cvr's 12's if i get alpine 4 alpine type r's if i get kicker cvx i will get 2 15's or l7's and if i get fi i will go with a single btl fully loaded
AmmanJordan
Post Number: 538
Ok , I know Atomic is 2 expensive .
Then try DD
its will be louder than kicker ( cvx , L7)
But in a perfect BOX ..
Chicago, Ill Us
Post Number: 2102
no i mean not too expensive, its like dd great products but i aonly have 600 to spend only on subs including shipping
and i want at least 2 woofer speacially 15's
Username: Riskyb
Post Number: 250
How about 3 Diamond D6 15's lilrob?
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1198
i know where to get two RE MT 12"s for 700 shipped if your interested.. its a local who goes to a lot of the shows I compete in.. he did a parking lot install with those two subs and ran them off an IA40.1 .. hit a 154.1
that was subs up port back..
Chicago, Ill Us
Post Number: 2104
yeha i beilve that man, but hey i dont have 4k rms and those mt will not take 2k for both
Username: Frkkevin
Post Number: 1208
... i'd just keep it simple with two L7 5"s.. I've seen those many times break 150s with the power you have ..
AmmanJordan
Post Number: 539
AS they all said L7's would be perfect in your setuation
Username: Mvplefty12
Pinellas, FLA America
Post Number: 115
Hey lil Rob, why not throw in a single 15" IA death penalty? I hear they can kill you...
Chicago, Ill Us
Post Number: 2119
na man it sjuzz like trhe juggenaut its pretty much same motor juzz a diferent fs and alil more xmax and stuff but both of them are pretty much the same.
i rather get a dd 9500 or a btl fully loaded
Post Number: 118
lilrob, you have aim?
Chicago, Ill Us
Post Number: 2122
na man i only have msn
Username: Jprix82
Post Number: 623
Hey rob im thinking about getting a explorer,what are the measurements of the cargo area - Wheel well to wheel well,bottom to top of the seats and back of the seats to back of the hatch? If you can get me this it would be great!
Chicago, Ill Us
Post Number: 2133
im nto sure but its prettyroomy i think its like 40 wide adn like 35 deep
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 576
Just bring a tape measure with you before you buy the vehicle lol.
