Wiring question!!! hurry!!
Username: Oglejust
Il Us
Post Number: 242
ok i have 1 dual 2ohm sub and 1 dual 4 ohm sub... wat r my possibilities and how do i do it?
Username: Tjmutlow
Post Number: 2986
what amp
Username: Oglejust
Il Us
Post Number: 243
it cant b any less than 2ohms
Username: Tjmutlow
Post Number: 2988
do you have 2 terminal cups in the box
Username: Oglejust
Il Us
Post Number: 244
they r in seperate boxes
Username: Tjmutlow
Post Number: 2994
is this a mono amp? hope so. ok run the dual 2 sub, + of 1 voice coil to - of other voice coil, run the wires to the terminal inside box, do the same for the other box.then run the wires to the amp, twisting + to + and - to -, it should create a 2.66 ohm load. as long as this is a mono amp.
Username: Oglejust
Il Us
Post Number: 245
well the amp is a 2 channel but ive been bridging it at 2 ohm and its not getting hot or anything so im pretty sure i can bridge 2.66ohms.
Username: Tjmutlow
Post Number: 2997
what brand is it and model # or you can run each sub voice coil + to +, - to -, do that for both subs, then on the wire going to amp go + to - and - to + (series) for a 3 ohm load.
