Ive been gone for a few weeks, my comptuers has been broken, but now im back...
Before i tell you all about the comp, the first thing i have to say is.....HOLY FU**KING SH*IT!!!!!!!!!!!!!!!! to the Memphis mojos. They had 2 guys there from Memphis both with 1 mojo 12 and 1 1100rms memphis amp. They both hit soooo loud. I dont know the xmax on them, but one of the guys when they played the sub, it looked like jelly. The sub looked like it had like 50mm of xmax. I couldnt believe it. Those mojos pushed sooo much air too!! Also, best sq i have heard so far out of any sub. It blew away my treo ssi in sq, and the louder it got, it didnt loose any sq.
I got 144.2 dB, and got 1st. I had my re sx 15 in a 3cu @ 35hz, running off of 1500rms.
not bad.. i don't believe the mojos beat a treo ssi in SQ though lol.. were you running outlaw by chance? do you have a car with the setup in the trunk? just wondering cuz i run with my drivers door open and trunk open..
with the trunk open i gain 2 dB so it might be worth a shot for you depending on the circumstances.. i went to a comp sunday.. only did 1 run cuz thats all it took.. burped 145.3 @ 42hz. what note did you use?!
.. pics! lol .. now where did you put the duct tape? along the whole surface of the port? i don't see it helping me any seeing the box has a layed of glass resin but i'd try anything cheap to gain .6dB lol
I do long pieces of tape that go from all the way inside the port (wrapping around to the inner wall of the box) and about 3" outside of the port.
The all the walls of the port are taped. The great thing about duct-tape is, you can just pull it back off if you dont gain. But you have to retape at each show.
sounds like something i might have to try.. of course i still need to design a new box but i might end up hooking up my other amp before i build a new box.. too curious to know what i'd be putting up for numbers with the extra 600-700rms.
