Ported vs. sealed
Username: Nyyfan13
VA USA
Post Number: 282
how big of a difference, in loudness, is it gonna be if i put my sub in a sealed box instead of a ported. i know it wont be as loud but i can probably figure out how to build a sealed box but im not so confident building a legit ported box. i really want a ported box but if its gonna save me $200 to build a sealed box then thats straight with me.
also, how hard is it to build a good ported box?
thanks
sorry if this post shows up twice, i did not see the first one.
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1955
lol....
FIRST OF ALL ITS NOT GUNNA TAKE 200 BUCKS TO BUILD A PORTED box(sry caps) and second of all it is fairly easy to build one
down load winISD(google it to find it) and tht program will help u the bast..
and the difference decible wise is normally 3dbs but u can get louder if to properly to incorporate ur car resosnant frequency....
but u can tune it wut u desire(30-35 good for lows; 35-40 decent sq and gets louder :o, and 40-45 with sum subs will still have monsterous output will sum whut decent sq; and 45-above id say strictly comps....)
and it is not hard at all to build a box
REMEMBER: its not rocket science its car audio :-)
Post Number: 1957
lol....
down load winISD(google it to find it) and tht program will help u the best..
and the difference decible wise is normally 3dbs but u can get louder if to properly to incorporate ur cars resosnant frequency....
but u can tune it wut u desire(30-35 good for lows; 35-40 decent sq and gets louder :o, and 40-45 with sum subs while still have monsterous output will sum whut decent sq; and 45-above id say strictly comps....)
Post Number: 1958
bump*second one has sum grammer corrected
WASSUPUSA
Post Number: 6202
^^^^^^^ROFL.
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1143
ported boxes are a lot easier than you may think.. the only hard part is determining what requency you want to tune to but everyone here can help you...
give us measurements and the subs you want to use and we can help you with a ported design.. or you can use this site..
http://www.subwoofertools.com/forum/ported-box.asp?
ported over sealed normally gives 3dB gain .. either box would cost the same to build if ou do it youself seeing you can only buy mdf by the 4x8 sheet
Username: Nyyfan13
VA USA
Post Number: 283
alrite, let me clear it up actually.
when i say "its gonna save me $200" i was referring to i was gonna have this installer build me the ported box becuase i didnt think i cuold do it but i was sure i could build a selaed box. and HE was gonna charge me $200 to build it for me. i know if i built it myslef itd be a whole lot cheaper.i hope i cleared that up and im sorry if my quesiotn was misleading.
Username: Nyyfan13
VA USA
Post Number: 284
i wanted a 2.5 cuft ported box tuned to about 32 hz. single 12" Fi SSD. i dont know the exact dimensions of my trunk, but its a small hatcback (scion tc)
Post Number: 1959
Tht will be quite easy to build..
u DO NOT HAVE TO PAY THT GUY 200$
tht is just a ripp
draw up sum plans and use tht program showed u
and then post ur plans on here and we'll check it
Pine hill, Nj US
Post Number: 527
You can do it!!!UploadUpload
Username: Nyyfan13
VA USA
Post Number: 285
alrite ill download that site later tonite and see wht it does for me.
thanks
ill try to post pics of what it gives me later tonite hopefully.
Username: Nyyfan13
VA USA
Post Number: 286
haha thanks paul for the encouragment.
Username: Frkkevin
Post Number: 1144
External Box Dimensions - 16x30x14
Port Dimensions - 12.5x2x25
Tuning frequency - 33hz
Total volume - 2.783cu.ft
After displacement - 2.238cu.ft
Box Parts (Square Prism)
1 Top, 1 Bottom: 14 (c) x 30 (b) in
0.75 (thick) in
1 Front, 1 Back: 13.5 (a) x 28.5 (d) in
0.75 (thick) in
2 Sides: 13.5 (a) x 14 (c) x 0.75 (thick) in
Vent Parts
1 Top, 1 Bottom: 2.25 (e) x 25.19 (h) in
0.125 (thick) in
2 Sides: 12.5 (g) x 25.19 (h) x 0.125 (thick) in
Username: Frkkevin
Post Number: 1145
Whoops.. forgot to make the port parts .75 inches.. changes things up a bit
Port Dimensions - 12.5x2x27
Total volume - 2.105cu.ft
After displacement - 2.989cu.ft
0.75 (thick) in
1 Front, 1 Back: 14.5 (a) x 28.5 (d) in
0.75 (thick) in
2 Sides: 14.5 (a) x 14 (c) x 0.75 (thick) in
Vent Parts
1 Top, 1 Bottom: 3.5 (e) x 26.99 (h) in
0.75 (thick) in
2 Sides: 12.5 (g) x 26.99 (h) x 0.75 (thick) in
Post Number: 1960
DAMN IT
LOL
nice job kevin u just saved him a sh!t load of time :-)
Username: Nyyfan13
VA USA
Post Number: 287
d@mn you are a couple steps a head of me man.
im guessing that gonna give me a 2.5 cuft box? if so thanks a whole man. i appreciate it.
ima go outside here in a minute and see if that box will fit,im just worried about the height cause of the hatchabck thing but hopefully it works.
Username: Nyyfan13
VA USA
Post Number: 288
im guessing that gonna give me a 2.5 cuft box? if so thanks a whole lot man. i appreciate it.
Username: Nyyfan13
VA USA
Post Number: 289
sorry about the double post but again
thanks a whole lot
Username: Frkkevin
Post Number: 1148
something about the forum today.. my posts on this topic keep disappearing...
Username: Frkkevin
Post Number: 1149
well sh!t i did it again lmfao ..
should be
Total volume - 2.989cu.ft
After displacement - 2.105cu.ft
.... its one of those days
Pine hill, Nj US
Post Number: 529
I've had at least 3 posts disappear today. BIG freakin mystery?? No, Ecoustacrap......Upload
Post Number: 1961
HAHAHHA
nice one paul
Username: Nyyfan13
VA USA
Post Number: 290
ok so my box size would be a 2.1 cuft box? that correct?
and i just checked the dimensions and they will work in the back so we're good there.
Username: Frkkevin
Post Number: 1150
and yes.. it would be 2.1cu.ft .. that is after displacement of the port and sub .. i figured that would be fine seeing its about middle of the specs provided from Fi
Username: Nyyfan13
VA USA
Post Number: 291
also would this be what my box would look like of am i imagining it wrong?
and yea i stole these pics from muddys system so thanks muddy. but is this what my box will resemble?
Username: Nyyfan13
VA USA
Post Number: 293
and yea i got no problem with 2.1, i just wanted to make sure i knew what was going on.
Username: Frkkevin
Post Number: 1151
similar yes.. if you want to get the loudest i'd fire the sub up and the port back .. i did not design a long port to fit on the bottom of the box because it would prolly not be very wide ..
placement is up to you... whichever you find easier
Username: Nyyfan13
VA USA
Post Number: 294
also, my dimensions u gave me were 16 30 14
is that 16 height, 30 wide, and 14 deep?
or 14 height, 30 wide, and 16 deep?
thanks for the help
Post Number: 1964
sub up ports back only works for SUVs
or so ive herd....
Username: Frkkevin
Post Number: 1152
16Hx30Wx14D
Username: Nyyfan13
VA USA
Post Number: 295
alrite good deal. the height fits in with about 4 inches to spare with the trunk cloed so we're good. thanks
Username: Nyyfan13
VA USA
Post Number: 296
the box will resemeble muddys up there and if i dont like how it sounds firing towards the rear of my car, can i just flip it up shooting up towards the roof? or is that just dumb?
Username: Frkkevin
Post Number: 1155
flip it however which may you think it sounds better.. reason i say it would be louder if you built if with the sub on top and the port on the side firing towards the back is because that scion is like a mini-suv of sort.. either way its going to sound good. i'd do whatever you were comfortable with. if you don't like it you can always build a new one later on down the road :-)
Username: Ctmike
Ct.
Post Number: 1953
i would never fire the sub up in a car. you think you have rattles now, wait till the sub is facing up, it'll be so much worse and it wont even sound good. just keep it firing to the back, best way in a car.
Username: Ctmike
Ct.
Post Number: 1954
ignore that^^, skipped right over you saying you got a hatchback.
Username: Nyyfan13
VA USA
Post Number: 300
yep and i just posted something but it got deleted. so i think ill make it and then go and listen to it the different ways and decide which is the better soiunding way
Username: Frkkevin
Post Number: 1157
sounds good.. post pics and let us know how it sounds :-)
Username: Nyyfan13
VA USA
Post Number: 301
http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=16&Dia=6&Xmax=21&Vd= .14&NumW=1&Vb=2.1&Fb=33&Qts=&Vas=&Fs=&CE=0
i know this is what kevin just did for me, but this is what im designing the box like, correct?
Username: Nyyfan13
VA USA
Post Number: 302
also, ive heard that u use 3/4" mdf i believe it is called to build the box out of. what does mdf stand for? and i do wanna use this correct?
and ill probably be bulding it this weekend hopefully altho ill be ordering the sub this weekend as well so expect pics of the box this weekend with no sub.
Username: Frkkevin
Post Number: 1161
medium density fibreboard.. and yes 3/4" MDF is ideal for box making. looking forward to those pics :-)
Username: Nyyfan13
VA USA
Post Number: 303
this is my first box as you can tell so hopefully things work out for me. how much of the mdf should i buy?
Username: Frkkevin
Post Number: 1162
sigh.. this is what i get for waking up and posting lol .. ignore the vent parts for making the port on that box..
make one L port 2 inches wide .. first piece will be 12 inches long.. then the second piece to make the L would be 14.25 inches long.. make sure the port is 2 inches wide the hole length when your putting it together..
if you want to fire the sub up and port back you can use the original design.. thats the only way that port would fit
Username: Nyyfan13
VA USA
Post Number: 304
ok kevin, im sorry to wake you up but can you give me your email address cause i believe i justc created what u just described on microsoft powerpoint and i want you to look at it and tell me if got everything correct on it.
i wont be on anymore tonite once i send it so if u could reveiew it sometime tonite or tomorrow and let me know in an email or on here id greatly appreciate it.
Username: Nyyfan13
VA USA
Post Number: 305
kevin, i sent u an email. i sent it to the email in your profile. sorry if you dont like getting emails from people on here but i figured u could help me out. my email is y2kmonkey33@aol.com.
Username: Hockeyknight
Post Number: 392
hey yanks good luck with that box!!! i just built my first ported box and it was a piece of cake! took about 3 hours (THANKS BASSMAN!!!) but just take ur time, pre drill every hole real good and get some elmers probond glue(worked great for me)
Username: Nyyfan13
VA USA
Post Number: 306
congrats on ur box and thanks.
Username: Nyyfan13
VA USA
Post Number: 307
kevin,
i got ur email and thanks so much man. ill build it this weekend and post pics of it.
Username: Frkkevin
Post Number: 1168
np.. looking forward to pics :-) .. take your time and pre-drill each hole well.. make sure to glue all the joints well too.
its best to piece the box together after you have everything cut to make sure it looks ok.. better to find out if something needs to be cut then rather than trying to do it when its attached to other pieces of wood already
Username: Basshead86
Try Google
Post Number: 6937
glad i could help:-) lol
Username: Nyyfan13
VA USA
Post Number: 308
haha yea muddy u helped without even saying anything.
