Mid-bass driver help (beyma 8") ?
Username: Impala63rag
Post Number: 104
i want to get some really loud and good quality mid-range bass. seen the beyma pro mi 8" mid-bass driver. is that a good choice? i just bought 2xdd 9512's. lookin for somethin that will go good with them. the beyma's are really expensive though. is there other options out there? what's the best way to do this?
Post Number: 105
how good are they kicker 8" mid-bass? are they going to produce the sound im lookin for? are the mid-bass subs superior to 6x9 in that freq. range?
Username: Basshead86
Try Google
Post Number: 6812
check out the Ascendant Audio Poly Mid:-)
Try Google
Post Number: 6813
it may only be a 6.5" but it is only $35 too
and it is high excursion....
Username: Bass__monkey
Las Vegas, Nevada U.S. of A.
Post Number: 157
is that the one using neo?
Try Google
Post Number: 6818
not sure....i don't think so.
Username: Adddisorder
West palm, Florida
Post Number: 1068
what about a tang bang 8 alteraudio has mentnioned them being nice. also id definatly look into the AA assassin 8s iv used the 12 and it really has amazing sq
Username: Rob_preg
NE, Ohio United states
Post Number: 683
tang band*
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1630
i have had tang bands before...i like them. id say get thoes or the AA
Post Number: 106
good lookin fellas, checkin on 'em now.
Post Number: 107
yeah, they look clean. aa assasin 8". for the price four of would be good. question!! would they sound right in the trunk or would i have to bring them in the cab with me? don't really have space for 'em, but will if i have to.
Post Number: 111
what frequency range should i be looking for?
Post Number: 115
can these drivers go in the trunk?
