Power keeps going off on my CD player
ChristopherW
I got a new CDplayer thinking it would fix the problem but it doesn't. When my car is stopped and i start going my power goes off then comes back on when i get up some speed. And the same thing when i slow back down to stop. We re-wired it and still the same problem. Also my steakers work like half the time. I can turn off my car and back on again and sometimes they start working again. Any thoughts?
Username: Cwjim
Columbus, Ohio Usa
Sounds like you may have a poor ground,the stereo case is floating in the dash,just a guess ,i don't know all the facts.
ChristopherW
Yeah its in a plastic case floating so is there a better way to ground it besides just the grounding wire?
Username: Cwjim
Columbus, Ohio Usa
If you can put a 12 guage wire from the fire wall,making sure you have bare metal connection for one end of the wire, then connect wire to the grounding post or screw on the back of your radio. -tight connections.---Hope that helps:]
