Fi SSD
Username: Nyyfan13
VA USA
Post Number: 240
i know these quesitons are hard to answer but give me your best shot. which would sound better in the back of a hatcback car in a ported box?
looking for sound quality and loudness.
Fi SSD or DD2512?
thanks
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1485
they are both nice subs.
Username: Basshead86
Try Google
Post Number: 6665
never heard a SSD, but i own an 2510 and couldn't complain:-)
Username: Nyyfan13
VA USA
Post Number: 241
i was thinking about getting the SSD in dual 2 ohm, does this mean i can wire it to 1 ohm? or just 2 ohm?
also would a 10" be as loud as the 12"?
thanks
Username: Nyyfan13
VA USA
Post Number: 242
didnt bump...
Try Google
Post Number: 6719
more cone on the 12" wins the loudness battle if they are the same sub....
D2 = 1 or 4
D1 = .5 or 2
D4 = 2 or 8
Username: Nyyfan13
VA USA
Post Number: 243
alrite then, ill prob get the dual 2 SSD. thanks man
Post Number: 1526
post pics when you get it.
Username: Nyyfan13
VA USA
Post Number: 244
will do, question tho, the rms is 800, i figure it can do a little more, how would a hifonics brutus bxi series bxi1206d amp do on it. it does 1200 rms at 1 ohm but its overrated i hear and only does abuot 80% of what it says it can do. would it be fine for the SSD tho?
Try Google
Post Number: 6720
yup....just make sure you set the gains correctly and watch the Bass Boost:-)
Username: Bass__monkey
Las Vegas, Nevada U.S. of A.
Post Number: 121
try to call scott at fi and ask for suggestions on custom ssd's...
Username: Nyyfan13
VA USA
Post Number: 245
what do u mean by "custom ssd"?
Try Google
Post Number: 6750
he can put a Custom Flatwind coil as well as other options he doesn't list on th websit to add to the sub for you specific application if oyu want them:-)
Username: Nyyfan13
VA USA
Post Number: 246
got ya, i was gonna get the flatwind coil cause its only $20 extra and i figured itd be better. anyother features i shuold look to include on the sub?
Try Google
Post Number: 6768
not sure, email scott:-)
Post Number: 1567
what kinda box are you gonna put it in?
Post Number: 1569
damnit didnt bump
Username: Nyyfan13
VA USA
Post Number: 248
ported, 2cuft myabe a lil bigger, tuned about 32hz
Post Number: 1574
yea, id do a little bigger....maybe 2.5-3cuft
Username: Nyyfan13
VA USA
Post Number: 249
yea i thinking ill prob go with 2.5
Post Number: 132
listen to muddy, fi subs can be customized. (stay tuned....)
Username: Nyyfan13
VA USA
Post Number: 250
alrite, im gonna order it either tonite or tomorrow. i need to get some new speakers too. im looking at getting Diamond Audio speakers, comps for front, coax for back.
Are Diamond Audio speakers legit?
Front - Ran of a Phoenix Gold R4.0:2 amp
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15024
Back - ran off headunit
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17167
Username: Nyyfan13
VA USA
Post Number: 251
my bad, these are the ones for the front
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15029
Username: Nyyfan13
VA USA
Post Number: 252
bump...
Username: Imperial_designs
Lafayette, Louisiana
the 2500 is IMO a better multi purpose woofer. good sealed box proformance and excellent ported box proformance. very underrated very good build quatitly and alot of expensive tooling. they easily handle 1K clean for musical purposes and can handle many times more for comps both therminal and mechinal. www.low-hz.com has them and ther authorized. very soon i will be reviewing hte 2512 and i will try to purshase a SSD because of the interest it poses.
