Cleaner sound from 4ohm opposed to 1ohm???
Username: Pike110
Post Number: 181
I am looking to change amps for my 2 12w6v2's and I was thinking about getting a rockford t20001bd 2000 watts. I was wanting this one because I could have some headroom for future subs. If I wire the subs to 4ohm and give them 750 watts which is about their rms. I can also wire them to 1 ohm for 2000 which is way overpower. Would I get a cleaner sound wiring the subs to 4ohm over 1ohm??
Username: Makmillion
MN United States
Post Number: 871
It won't be noticable, more than likely.. but at 4 ohms there will be less stress on the amp.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2700
one will run cooler, just that... people say that you lose quality when you run at 1 ohm, but i always prefer running the amp matching with the specs. I'd run it at 1 ohm
Username: Pike110
Post Number: 182
I didn't think there would be an audible difference... just making sure.
Username: 420alldaylong
Post Number: 440
Pike110
At 4ohm on the Rockford T20001BD it pushes over 1100 watts so that's to much for those JL Audio subs if you put to much power to JL subs the warranty is know good.
Username: Juliob
Post Number: 2723
the dampening factor is not the same, but when it comes to a good quality amp shouldn't be a problem like the rockford you own
Post Number: 442
Pike110
RockFord Fosgate T20001BD
Over 1000 Watts at 4ohm
Over 2000 Watts at 2ohm
Over 2700 Watts at 1ohm
