Power Acoustics
Username: Aj1218
Post Number: 7
Hey does anyone know if the Power Acoustiks 12 inch FUBR 1800 watt sub is worth the money. Also do they perform better in sealed or vented enclosures. Thanks
Username: Makmillion
MN United States
Post Number: 851
it's worth the money, if you can get it for less than 40 shipped :-)
id put it in a sealed enclosure..
BUT
there are alot better out there than power acoustik
Username: Aj1218
Post Number: 8
I know there are better subs out there, Im just looking for relatively cheap 12 inch subs over 500 RMS. Do you have any reccomendations? Thanks
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 598
ASCENDANT AUDIO ARSENALS.. only 180 each...I consider that cheap.
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1428
alpine type r
Post Number: 1429
kicker cvr
Post Number: 1430
what do you consider cheap?
