Flat Wind Coil on SSD???
Username: Freezeman_7
Lindsay, Oklahoma
Post Number: 287
hey guys. muddy finally talked me into the fi ssd's i think i will be
really happy.. now i plan on ordering them by the end of the week. so
do i want Flat Wind Coil? or no. and Dual 1 or Dual 2. i cant find any
wiring diagrams that show me how to wire dual 1 ohm subs. but ive
found dual 2 and it can be wired to 2ohms or .5 ohms. so does anyone
no of a 2000wrms sub @2ohms... thanks
Username: Drsmith
Montana USA
Post Number: 1032
how about 2 1000 watt amps?
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1018
DVC 1 ohm can be wired to 0.5 ohm or 2 ohm
DVC 2 ohm can be wired to 1.0 ohn or 4 ohm
So as far as which coild type depends on what type of amp you have or are going to run.
I'm not expert and don't know much about the difference between the coils but subs with the flat wind coil tend to be the better buy. I've been told the differene but can't remember it... ugh. Something about allowing the coil to flow more current.. more surface area..
Username: Frkkevin
Post Number: 1019
oh whoops.. sorry. did not see you were getting two.. completely changes the wiring.. what i posted was for single sub
Lindsay, Oklahoma
Post Number: 289
nope dvc 2 ohm cant be wired to one. according to crutchfield and the 12volt. here ill show you
2-ohm DVC .5-ohm load, 2-ohm load, or 8-ohm load
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC2x2
i just cant find a diagram dvc 1ohm
Lindsay, Oklahoma
Post Number: 290
oh my bad then... haha its cool yep 2 twelves. jus cant decide on dual 1 or 2 and flatwind or not?
Username: Basshead86
Try Google
Post Number: 6549
The flatwind allows for a little more coil(increasing overall strength and lowering the qts)in the gap as well as a little better power handling.
Lindsay, Oklahoma
Post Number: 292
sweet. so go for the flat wind? ok. now dual 1 or dual 2 ohm. think you know if im gonna buy the sub why not get it done right. so ill def do the flat wind
Try Google
Post Number: 6552
the ohm config will depend on what amp you get...more than likely though you will want the Dual 2 ohms to get a final impedance of 1ohm for the amp.
Username: Rovin
Trinidad & T...
Post Number: 9245
u only live once so u might as well stop pinching pennies get it fully modded ....
...Upload
Try Google
Post Number: 6555
LOL^^^
he has a point ladies and gentleman..
Upload<---and aren't these sweet???? lmf*ckingao
Username: Rovin
Trinidad & T...
Post Number: 9247
eeeeeew no ! ^ that looks like a guy wit T/I/T/S .....Upload
Username: Kaos15th
Post Number: 218
these are better lolUploadUpload
Username: Rovin
Trinidad & T...
Post Number: 9248
well since the forum is quiet now & u all r bringing out pix ......>>>>>>>>>
Username: Drsmith
Montana USA
Post Number: 1039
^^^^^ nice
Username: Kaos15th
Post Number: 220
Lindsay, Oklahoma
Post Number: 296
you cant wire a dual voice coil 2ohm sub to 1ohm. its impossible. or tahts what crutchfield and the12volt says...
Lindsay, Oklahoma
Post Number: 297
ordering 2NITE. FI SSD 12' (2) Flatwind coil Dual Voice Coil 2OHM
Username: Cenus
4, 2 0
Post Number: 2340
whats the rms on those subs, i think there 1000wrms, if so i'd look for a kx2500.1, it does 2500wrms@2ohm, wire 2 dvc2ohm series/parrellel for a 2ohm load.
Username: Cenus
4, 2 0
Post Number: 2341
Lindsay, Oklahoma
Post Number: 304
exactly someone who understands me. it has to be at 2 ohms. thank you dustin.
Lindsay, Oklahoma
Post Number: 305
Username: Cenus
4, 2 0
Post Number: 2342
NP man, just remember to upgrade the alt, with that much power.
Lindsay, Oklahoma
Post Number: 308
oh yeah i know it. ive been lookin for about a 180-200amp alt. havent had any luck yet tho
Lindsay, Oklahoma
Post Number: 309
https://www.ecoustics.com/electronics/forum/car-audio/275082.html
Try Google
Post Number: 6608
post pics when you get them:-)
