Eclipse type x
Username: Rvlacos
El Paso, T.X. United States
Post Number: 18
has anyone heard these or have an opinion on them?
Username: Rvlacos
Post Number: 19
sorry bout that they are alpine. ALPINE SWX-1242D
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2007
they are very musical that means they sound super good, but they dont get too loud but resonable loud
Username: Makmillion
MN United States
Post Number: 754
I heard a set of SWX1042D's.. custom enclosure to alpine specs running on 2 PDX-1.1000's and they sounded like type-r's with a higher distortion to them at high volume :\
Username: Rvlacos
Post Number: 20
well thats not good.....
Chicago, Ill Us
Post Number: 2010
hey mick where did u heard that?? u got a link or someting?
Username: Ctmike
Ct.
Post Number: 1903
not worth the money, unless you get a really great deal on them. i'd take a pair of r's over the x's. you have a budget for subs?
Los Angeles, CA USA
Post Number: 6003
i'd take type Xs over Rs anyday. the type r doesn't even compare to the type x in sq. only downside of the type x is that you need some serious power to get them loud where a pair of type rs can get loud with only 1000wrms. still the sq is much better on the type x.
Username: Basshead86
Try Google
Post Number: 6563
SCREW ALPINE....
/thread
j/k j/k
heard an R at best buy the other day....R < good sound..
MN United States
Post Number: 756
link? LMAO! No :-) At the shop..
also, I used to own two 12" type r dual 4 ohm subs.. I loved them and I'd trade my eclipses for 4 of them (but only if it could run @ a 2 ohm load)
