Fiberglass fleece
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 690
any1 now where i can find it cheap the strechy kind for makin custom stuff cause iam thinkin of makin custom rear deck wit 2 6x9s an amp in the middle for all speakers an might do all interior lol if u no any sites let me no
Username: Jmloughrey
Farmington, CT
Post Number: 1616
www.homedepot.com
www.lowes.com
www.your local hardware store.com
Username: Adddisorder
West palm, Florida
Post Number: 947
or you can just use speaker grill cover
Post Number: 691
could i just use fleece from a fabric store? but still gota buy resin 2 make it hard so could i use fleece from a store
Username: Tdawg30
Ohio USA
Post Number: 272
yep. its cheap and hassle free. try and get the stretchiest stuff there cuz some of the fleeces are thicker than others and hard to make wrinkle free.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 3124
walmart or any place that sells fabric should have it.
Username: Frkkevin
Lake Worth, Texas US
Post Number: 995
if you want something stronger you can use the stretch automotive carpet.. harder to find but overall is better.. fleece is the cheap route and works fine. just be patient and buy lots of sandpaper :-) .. don't get disappointed if it wrinkles on you.. just get some body filler and you'll be a-ok ...
Username: Renegadesrun
Lafayette, IN US
Post Number: 146
Fleece is the cheap route...and best IMO.
One stipulation. Buy 100% polyester. Not cotton.
Cotton will not melt and become "one" with your resin. Polyester will. The end result is much stonger using the poly vs cotton.
Post Number: 692
sweet thankx i was kinda thinkin of dat fleece an might go out 2 joann fabrics an buy that an sum more furr might fiberglass my head liner an sum other stuff since i got no room 2 do a custom rear deck since its 2 close 2 da back window
Lafayette, IN US
Post Number: 160
Joanne is exactly where we get our fabrics.
Fleece and otherwise.
Post Number: 693
any other stuff i can also use??
