Interchangable ports
Username: Rhassler
Gilford, NH
Post Number: 619
Aight, i think im set on gettn 2 Havoc 15's. Now i want to make a box with interchangeable ports, anyone have a site or sumthin to help?
Username: Frkkevin
Lake Worth, Texas US
Post Number: 993
easiest thing to do is aeros .. lets say 3 13inch aeros tuned to 45hz.. plug one its tuned to 36.. plug two its tuned to 28hz.. or course that was just an example not exact math.. what do you want to do? compete and have a daily or just have different ports to change for the heell of it
Username: Rhassler
Gilford, NH
Post Number: 620
well, i want to have it as a daily driver, but i also wanna go to local comps so i wanna be able to switch the ports
Username: Frkkevin
Post Number: 997
you could build slot ports that are interchanagle depending on box depth.. might have to sacfrice more.. aeros or pvc ports are eaier to interchange plus easier to plug unless you build a special plug for the slots
Username: Makmillion
MN United States
Post Number: 707
You could build ports out of PVC (correct me if I'm wrong, I don't do ported boxes.. this is just an idea) and you can get those threaded pvc plugs/caps, they use them on septic systems..if you know what I'm talking about.. when you want it sealed or tuned lower just plug one, or two or three etc..
Username: Rhassler
Gilford, NH
Post Number: 621
hmmm Kevin, how would i go about makin aeros?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3723
you just calculate them. i great program is winIDS, and when you use that, add around an inch to the final port length becase of the flare.
aeros are expensive too
Username: Frkkevin
Post Number: 1000
they are about 12-15 bucks depending on where you get them.. partsexpress sell them for a reasonable price. and yeah you add about an inch to the port lenght if you use a calculator that does not have aeros in it.. i use bass box pro 6 but it has both single flared aeros and both ends flared.. calculates it all.. great proggy :-)
