How exactly do you bridge an amp?
Username: J_capone
Chicago, IL USA
Post Number: 7
ok..
i never done this before..and i found a little tutorial, but it seems like it was for hooking up one sub only..
question is..do you only bridge an amp if you have one sub?
if not..
then how would that work?
i have a boss ripper amp..2 channel thats bridgeable..with 2 audiobahn subs..
anybody?
jj
you can not bridge 2 subs with a 2 channel amp you bridge 2 subs when using a 4 channel amp. you just wire them strait to the amp that is giving you a 2 ohm load that is all you can do with that unless you got the money to get a 4 channel but it will sound good hooking it up let i said.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2801
http://www.bcae1.com/bridging.htm
Username: J_capone
Chicago, IL USA
Post Number: 8
damn..nice link
good stuff
thanks
