Alpine type-e comments?
i'm looking for a good budget sub to replace my 2 shitty thumps :D
alpine type-e is cheap and it looks promising.
note that I probably only need one, sinc eI have a 2 seater truck with the sub(s) right against the seat
what amp have you got?
300W lightning audio
Username: Sploosh56
Post Number: 15
I have a friend with 2 10" Alpine type E subs. They are a quality sub for the price. They distort a bit when they get a lot of power into them but with the amp you said you will use it will be just fine.
as long as thats 300w rms and not just peak power it should be ok as the type-e 12" is 300w rms, id preffer an infinity reference 1232w in a sealed box, similar price.
