Head unit install 2004 Hyundai Elantra
Username: Mad_at_madd
Chico, CA USA
Post Number: 32
I'm installing a head unit in a 2004 hyundai elantra and I can't figure out how to get the dash panel out so I can get to the factory mounting screws. Can anyone please help me?
Travis
Username: Jenifer_contreras
PIMP Member, Yokosuka, Ka...
Post Number: 873
1.Disconnect the negative(-) battery terminal.
2.Remove the 2 screws holding the instrument facia panel.
3.Open the ashtray then remove the ashtray assembly after pushing the plate down.
4.Remove the 2 screws after removing the ashtray.
5.Disconnect the connectors from the instrument facia panel.
6.Remove the audio unit after removing 4 screws.
Good Luck!
Post Number: 925
So you get it or not!
Post Number: 926
if yes ,then give me some credits!
