Yes, you can hook two sets of speakers to a single channel, but make sure your amp can handle the ohm load..
and
Yes, you can bridge a 2 channel amp to run a set of component speakers, but you will lose the surround effect because both speakers will be run from one single channel, so they will both behave exactly the same.
