Dual alts 1 oem 1 ho?
Username: Bernymac
Rialto, CA United States
Post Number: 308
What I'm asking is, can I keep my stock alternator to run my car accessories, and get a HO alternator on a bracket to run my sound system? Anyone ever heard of this done. I can't see why not is the main reason.
Username: Adddisorder
West palm, Florida
Post Number: 882
yeah just have to have a seperate battery for the HO
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 3058
you can do that with no problem if you have the space for the extra alternator and battery.
Username: Rev_ike
FT CAMPBELL, KY
I WOULD'NT GO THRU THE DRAMA, CAUSE YOU UPGRADE ALT HAS MORE THEN ENOUGH TO HANDLE WHAT IS ALREADY IN YOUR RIDE...YA DIG !!
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 384
It would prolly be more costly in cash and time than just paying for a single HO alt to run everything.I would shell out the money and get the lifetime warranty on a HO alt from Iraggi.
Username: Fandim
Reno, Nevada United State...
Post Number: 1371
Brackets are not expensive to have even fabricated. A local shop (Infinite Velocity Motorsports) can build me a bracket for my 1999 Firebird for under $200. And assuming that a single HO alt is enough to run his vehicle, and his system, is a silly assumption. A single Orion 2500D etc can use up a HO alt all by itself very easily, especially if it's a small case.
Username: Cavsmaxima
New York United States
Post Number: 361
jus get an upgrade alt
Username: Th3pwn3r
Post Number: 440
Lol a bracket for 200 bucks,what a rip off.
Username: Bernymac
Post Number: 334
Ok what do you think. 1 HO alt anywhere from 220A to 300A, I like the lower outputs bc they give higher outputs at idle, but consider two odyssey 2150S batteries. (its like having 4 yellow tops). You think 220A's would be fine? consider the batteries.
Username: Fandim
Post Number: 1374
A bracket for $200 isnt so bad - when you consider there isnt one pre-made for my car/engine size. It needs to be custom fabricated.
Stockbridge, GA USA
Post Number: 3106
not bad expecially for a newer car. i've made brackets for some 60's model cars i've worked on, they are easy. new stuff can be a huge pain in the a-s.
Username: Carguy
Post Number: 5666
It's not about custom made brackets, but mostly space in newer cars. There's not even enough room for your arm to go in to get anything out under the hood nowdays.
The old cars from the 80's were the best. You can easily install anything, even have room for you to stick your head inside too.
Post Number: 367
"You can easily install anything, even have room for you to stick your head inside too."
lolol doesnt sound to safe
