WILL 2 KICKER SOLO-X S18X FIT IN AN 2004 IMPALA SS ????
Username: Dabigpapa
Post Number: 15
Will 2 KICKER SOLO-X S18X fit into a 2004 IMPALA SS. Thanks.
Username: Night_mirage
AmmanJordan
Post Number: 505
Whaaaaaaat ?????
Username: Mr_kebo
Albertville, Al USA
Post Number: 508
If you go ported it will be a pretty large box if i had to guess. Never seen the trunk. Give us some dimensions and well see
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 507
naw..im sure it wont...two 15" l7s barely fit
Username: Hockeyknight
Post Number: 308
maybe if you knock out the back seats and have the box flair out into the cabin and face the subs forward.......that would be a kick a?$ install
Username: Johnfiac
Il USA
Post Number: 426
you can get those to fit id think thats a big @ss trunk aint it?
Post Number: 311
i dont know where u would put the batteries and amps if u planned to run those badboy as full power
Username: Tjmutlow
Post Number: 2843
i doubt it a single sub needs like 5 cub ft I think.
Username: Seth_walker
U.S.A.
Post Number: 157
Dimensions would help alot. You'd probably need to use your entire trunk which makes me wonder how you'll fit it through the opening? a few people in this forum have had trouble with that. Major props to you if you can pull it off.
Username: Troy81
Tavernier, Fl Us
Post Number: 1134
immma do it so if you wanna beat me to it you better hurry
Los Angeles, CA USA
Post Number: 5822
you gonna have to take out the spare tire and mount the amps in there. also you can stick 2 batteries in the outer corner of the trunks. one on each side.
then you have to build the box inside the trunk to get the most available space. you can't build it and try to stick it in. it won't fit.
bad side of this is that you have to adjust all your amp settings before putting it all in cause once the box is built thats it man. no access to your amps.
this is how someone i know installed 2 18x's in his impala.
Username: Dabigpapa
Post Number: 17
DAMN it looks like too much work & too much money & plus i want my back seats. so it looks like I have narowed it down to two different subs I will either be gettin 2 JL 13W7 or 2 KICKER Solo-X S12X I need help deciding which couple to get PLZ advise. Thanks.
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 334
Buy something besides the W7's.We can reccomend many subs that are better for cheaper.
Los Angeles, CA USA
Post Number: 5826
dave you can go for 1 solo x 18. that sh!t will tear your car in half. it is so loud.
Los Angeles, CA USA
Post Number: 5828
bump damn it bump.
Username: Th3pwn3r
Post Number: 335
For a car you wouldn't need more than one Solo X 18 lol.I'll be getting a 2nd Solo X 18 soon though :-) But that's for a van.If you want to put 2 in your car it will take up the whole back area...you would have to rip out your back seat.I would do it personally lol...but that's me I'm crazy like that.
Username: Th3pwn3r
Post Number: 336
By the way...you would still need tons of room for the 12 inch versions of the X.I don't think your trunk would be enough room.
