Gold Member Username: JmloughreyFarmington, CT Post Number: 1605 Registered: Jul-04 | Are they any good what so ever? Why the hell are they so cheap? http://www.ikesound.com/product-product_id/3379 thinking two of them bridged at 4 ohms for my new system... |
Gold Member Username: Alias747MN Post Number: 1347 Registered: Apr-05 | Dude, buy them and give a review! At that price, you can't go wrong! |
Silver Member Username: Sb2012Iowa US Post Number: 271 Registered: Jul-06 | ive read they are very good and are very underrated and typically really expensive...go for it |
Gold Member Username: Alias747MN Post Number: 1348 Registered: Apr-05 | ^^^ The old US amps were killer, they could have gone down hill with many of the use-to-be car audio OG brands... |
Gold Member Username: JmloughreyFarmington, CT Post Number: 1607 Registered: Jul-04 | "^^^ The old US amps were killer, they could have gone down hill with many of the use-to-be car audio OG brands..." This is whats worrying me, i'm more afraid my subs are going to break them. My Orion HCCA's are power hungry beasts... Alot of new stuff isnt built to the same specs as the old stuff...unfortunatly, alot of the time the older stuff is much more solidly made. |
Gold Member Username: StnorrisIA US Post Number: 1403 Registered: Apr-06 | woww.....that is insanely cheap |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 6082 Registered: Aug-05 | if you go U.S.Amps, stick with the AX line. you should be fine all the others i have heard have been outsourced. |
