Audio Control three.1
Username: Afroopuff
Post Number: 242
Anyone had anyexperience? I know that audiocontrol is a great company but I'm a little unsure about it. I was thinking that I could use the speaker level inputs to use from my radio the the three.1, then take my ipod and use RCA's as an input, then on the output i have front to my speakers amp and sub to my sub amp. Is this set up possible? Called Al and Ed's and guy said i cant use the Ipod in this situation....he is a dumb SOB so i dont nkow if i should believe him, what do you guys think? workable?
Username: Tjmutlow
Post Number: 2819
i do not think so, or at least both units can not be on at the same time, also not sure will the IPOd have voltage output, if it oes not, I do not think it will work. and itis a great piece, i use it with my AVIC-D1
Username: Afroopuff
Post Number: 243
i understand that both units cant be on at the same time, that is okay, but whats with the voltage output? i dont even know where to read about stuff like this so sorry, thanks dude
Username: Afroopuff
Post Number: 246
ty?
