Whats the exmax and driver discplacment for a 10" l5??
Username: Dustin3
Tigard, OR U.S.
Post Number: 3458
cant find it on their site. or on their online manual... does anyone know the EXACT numbers??
Username: Naledge503
Portland, Oregon U.S.
Post Number: 223
xmax 15.2 mm
displacement 95.6 cu. inches or 1570 cc
Username: Dustin3
Tigard, OR U.S.
Post Number: 3459
the xmax is not 15.2 mm. it should be under 1.
Post Number: 224
I got that straight off the kicker website.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3460
thats weird. cause it shouls not be that high. i think the cvr is like .498
Post Number: 225
Maybe i'm wrong, go look at the kicker website. click support/ scroll down to technical support/ then move over to T/S parameters. Thats where i got my info.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3461
i think ur right nm.
how do you get from 95.6 cu inch to cu ft?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3462
95.6/1728 = .055324.. this right?
Post Number: 226
I dunno, your the one in calculus or some sh*t..lol... I think its 95.6 divided by 12
Username: Mr_kebo
Albertville, Al USA
Post Number: 493
Yes that is right bassman3
Post Number: 227
what is 1728 in that equation?
Username: Dustin3
Tigard, OR U.S.
Post Number: 3463
wait. ok
on my cvr it says:
net displacment = 122.1 cu inch
{exmax} in (mm) = .498 (12.64)
so for the xmax for a cvr (like in subwoofer tools) you put 12.64 mm or .498?
cause im confused if that means in mm or (inches) (mm)
Username: Mr_kebo
Albertville, Al USA
Post Number: 494
12.64
Username: Dustin3
Tigard, OR U.S.
Post Number: 3464
im drawin a huge blank, lol. cause every time i have made a box it just says it in mm
Username: Dustin3
Tigard, OR U.S.
Post Number: 3465
yea
thats what i thought.
