Bronze Member Username: SvtmassaPost Number: 13 Registered: Sep-06 | I had 1 10" jl 10w6v2 hooked up to a kenwood kac-9152d and the jl doesnt get loud enough for my taste... or the amp sucks? anyways, i am starting over I am looking for a 1000w or so rms amp i have in mind kx 1200.1 jbl 1200 infinity 1211a pheonix gold xenon 1200.1 I would probably want two 12 inch subs in a ported box. what kind of subs?? i am going for loudness over sound quality i want to keep the subs $200 or less for each one. thanks |
Gold Member Username: CtmikeCt. Post Number: 1738 Registered: Feb-06 | can you bump up your budget? or you open to buying used/ebay? |
Silver Member Username: DrsmithMontana USA Post Number: 599 Registered: Nov-04 | 2 audioque SD2.5's http://www.audioque.com/aq/order.htm should be well under budget |
Silver Member Username: Sb2012Iowa US Post Number: 257 Registered: Jul-06 | well the kicker kx1200.1 will actually put out about 1400 watts or so...try 2 AA arsenenals...or if u wanted to go one 12" for 1000 watts look into an AQ SD2.5...i think it was logan that hit 137.2 with just one and only 600 watts you could also get an FI Q...which ive heard is better than the 05 xxx...thats sayin a LOT ![]() |
