Bronze Member Username: Bump05Hesperia, CA USA Post Number: 62 Registered: Aug-06 | would this amp work for 2 kicker 15" l7's (2ohm) http://cgi.ebay.com/ebaymotors/NEW-LANZAR-4000-WATT-2-CHANNEL-CAR-AUDIO-AMPLIFIE R-AMP_W0QQcmdZViewItemQQcategoryZ38638QQihZ017QQitemZ270025932980QQrdZ1 |
Silver Member Username: Rick_rossPost Number: 493 Registered: May-06 | no that amp sucks youll need at least $500 to get a decent amp for them |
Silver Member Username: Rob_pregYoungstown, Ohio United states Post Number: 611 Registered: Sep-05 | 150 bucks isn't a reasonable amount for an amp to properly push two L7 15's. you might be able to get lucky with $300-350... |
Bronze Member Username: NoviceinstallerHere, There Post Number: 27 Registered: Sep-06 | i have 2 15 inch kicker L7 2ohm and i have them on a PowerAcoustik Class D Series #A1800DB i paid like 350 for it and it does an excellent job....... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2302 Registered: Dec-05 | ray you're underpowering those subs real bad... what you need is 1500w rms at 2 ohms. Kicker Zx 1500 would be the best or a PA a2400db so it will put like 1500w at 2 ohms |
