Port noise
Username: Adddisorder
West palm, Florida
Post Number: 784
im building a 2cube box at 35hz for my 3512 anyway im going to use aeros. i want to use just one 4"flared which i think will be like 12-13" long whatever is 35hz. but i was told ill probly get port noise. what do you think? i dont want to have to add another port becasue then they will each have to be like 24" long
Username: Rovin
Trinidad & T...
Post Number: 9053
i doubt u will get port noise with a flared aero
look @ this - 3" pvc & no port noise .....
https://www.ecoustics.com/electronics/forum/car-audio/266392.html
West palm, Florida
Post Number: 785
ok thanks rovin i didnt think id have a problem with it but just wanted to make sure befor i started building becasue it i had to add 2 24" 4"flared that would be a lot of internal volume it would take up. i talked to marshall about makeing the box and he never said anything about port noise either so i guess its cool i get to go start building now!
