Ya or Naw???
Username: Thomas_g
NM
Post Number: 1698
Do ya think that 1000-1200rms of clean watts will harm a DD 2515?? Thanx.....
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1659
muddy is runnin 900 clean watts into his 10"
but im not sure bout 1200...
Username: Thomas_g
NM
Post Number: 1700
Damn.......thanx....
Username: James1115
Ct
Post Number: 6561
it should be fine, just have control.
Username: Sb2012
Iowa US
Post Number: 219
DD forum says it will tak 1500 rms and is recomended at 1000 for music power...and muddy often recommends 1200 watts
If it were me id stay closer to the 1000 just to be safe..
keep in mind these are CLEAN watts
Username: Crayola0
Wisconsin
Post Number: 1029
tj...we are thinkin about the same setup and im looking at an ed nine.1 so if i were u taht would be a good amp cause it puts out 1200 watts at 12.2 volts
Username: Ctmike
Ct.
Post Number: 1660
if you get a nine.1 it'd be better to run it at 2ohm. it's underrated and at 1ohm might put out to much power for it.
Username: Basshead86
Google is your Friend, FL
Post Number: 5819
the whole reason i stress CLEAN watts...is b/c any sub will blow with dirty watts....but the DD's cool themselves VERY effectively with their Free Flow Cooling System(tons of vents and canals machined throughout the motor system to transfer heat and moving air around the VC)
so if it isn't playing correctly aka distortion...then it won't cool properly...thus taking away the advantage of the FFCS.:-)
...and then you blow them like andyF did....lol
Username: Sb2012
Iowa US
Post Number: 222
lmao^
Username: Thomas_g
NM
Post Number: 1707
lol thanx every1, i was thinkin of runnin 1 2515 off 2 ohms then later gettin anotha and runnin both off 1 ohm, im pretty good with controlling the distortion outta my subs, so should i do it?? ya and hey James i sold my setup yesterday so i should have this setup within the next couple of weeks :-) :-) :-) :-) lol
Username: Crayola0
Wisconsin
Post Number: 1035
which sub is more spl oriented the 2515 or 3515 and how much does the 3515 cost..
Username: Redliner
Wilmington, Ma
Post Number: 2379
if you have the money go for the 3500 series they are awesome not only do they get loud they ound amazing also
Username: Crayola0
Wisconsin
Post Number: 1037
do u know how much they are?
Username: Atllefty12
FL.
Post Number: 376
$387 plus shipping if you qualify for the 20% discount. The discount is if there isnt a dealer within 100 miles of you.
Username: Crayola0
Wisconsin
Post Number: 1038
how much without the discount...and how much is the 2515 without the discount?
Username: Redliner
Wilmington, Ma
Post Number: 2381
add 20% to the 387 and i believe the 2500 is somewhere around 200 but not positive you'll have to ask someone else that knows btter then me sorry i cant help
Username: Crayola0
Wisconsin
Post Number: 1040
the 3515 is too expensive for me so ill have to go with the 2515 what amp should i get..thats around $300
