**For Sale**
Username: Frkkevin
Lake Worth, Texas US
Post Number: 577
Heres the measurements and tuning frequency. Remember the tuning frequency will change with the displacement of the driver so if you are interested give me the the volume of your sub and I'll input it to tell you what the new tune is.
Type: Vented Box
Shape: Prism, square
Vb = 4.341 cu.ft
Fb = 45hz
Fill = none
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 14.5 in
Wv = 4 in
Lv = 13 in
As far as pricing.. all offers will be considered.
Username: Delsole
Post Number: 635
whats that sub in the backround
Username: Frkkevin
Post Number: 580
Memphis LVS 15" .. tempted to wall socket it.. need a digital video recorder before that though so I can show all the Memphis lovers what I think of their subs :P .. but idk I may sell it also
Username: Delsole
Post Number: 637
its pretty hot lookin
Username: Frkkevin
Post Number: 581
Its alright.. way overpriced. If you get a chance look up the msrp on that lol. I was using it while my RE SX 15" was getting reconed. That sub does have some flexing power and hits the lows nice but just does not get as loud as my current setup. It is just my backup sub..
Username: Troy81
Tavernier, Fl Us
Post Number: 1044
how much you want?
Username: Troy81
Tavernier, Fl Us
Post Number: 1045
for the sub ***
Username: Frkkevin
Post Number: 582
I really did not want to sell it due to its condition.. It was in a car accident when I aquired it and a piece of the basket broke. I fixed the basket and re-glue the rubber surround and it works perfectly but like I said I would not really want to sell anything that has the potential to taking a crap on them. I'm not sure what it is even worth...
Username: Rideredder
Cornell, IL USA
Post Number: 477
I'll pay the shipping charge if you give it to me for free.
Username: Frkkevin
Post Number: 586
Lol.. I'd sell the box for $50 + shipping .. if no one wants it on here I can for sure sell it local. As far as the sub.. It works and sounds fine thats why I was going to keep it.. just in case my SX needs another recone lol
Username: Frkkevin
Post Number: 595
bump
Username: Makmillion
MN United States
Post Number: 199
the box is for as 15?
Username: Frkkevin
Post Number: 597
yes.. i built it for a RE SX 15"
Username: Mr_kebo
Albertville, Al USA
Post Number: 439
box looks ruff
Username: Frkkevin
Post Number: 598
not the least bit.. sub was only mounted in it for 3 8second burps.. the discoloring on the side of that is simple glass resin that might have gotten onto the side.. its gorilla glued with 1-5/8" screws and glass resin on the inside..
Username: Jemone
Stone Mountain, Georgia United States
Post Number: 131
those elvis subs do quake, but they are overpriced. a local shop that i used to frequent said they would sell me a used one for$900 us. But like you said kevin they dont seem to get as loud as you think they should for that price.
Username: Frkkevin
Post Number: 600
They were suppose to be for SQ. Don't get me wrong they sound decent but don't get as loud as the RE SX... They do have some flexing power though.. guess its all the extra moving mass
Username: Jemone
Post Number: 132
above all memphis makes good subs one of the loudest low price setups i have ever had was with one of there 12s in a slot ported box. i not sure of the series of sub, but it was loud. I had it on a 500 watt lightning audio amp.
Username: Frkkevin
Post Number: 601
They make decent subs but for the money there are better.. of course that can go just about for anything :-)
Username: Frkkevin
Post Number: 603
bump.. no one needs a box?
MN United States
Post Number: 220
I need one for TWO 15s if you have something else laying around..?
Username: Frkkevin
Post Number: 608
My entertainment center is a box for 2 15"s.. 14^3ft tuned to 28hz.. came out of a 01 Silerado but I'd imagine thats too big lol .. has to 15"s downfiring now for my home theater. Wish I had something else but really just have this one extra box.. only reason I'm selling it is to get back the money I spent for materials so I can get my new box started. What kind of vehicle are the 15"s going in btw?
MN United States
Post Number: 221
91 honda accord ex 4dr. they're in it now in a huge up firing box and i want them to fire back towards the tail lights..
Username: Frkkevin
Post Number: 609
Is it ported or sealed btw?
MN United States
Post Number: 222
3.68 cu. ft. divided to two chambers sealed, 1 1/4" MDF, up firing design.
Username: Frkkevin
Post Number: 612
Not enough box for two ported.. ever consider running just one in a ported box? In most cases the gain you'd see by porting would make that 1 sub as loud if not louder than the 2 sealed..
At a few comps my SX have gone up agaisn't setups such as 2 audiopipe 15"s, 4 kicker L7 15s, 4 Kicker CVR 12"s.. ect.. all of which did not do as well on the TL as my single ported setup. Those audiopipe were ported but the box was too small to have to 15s so it was pointless to have two in it.. and either of those other setups could have done as good as me by dropping the amount of subs with the same box size and just porting it. Those L7s were capable of 150s but with the sealed box it only did a 144..
MN United States
Post Number: 227
I have, but my amp will only put out 350-400 rms at 4 ohms, my subs are svc 4 ohm each.
My box is sealed, now, though.
Eclipse recommends, strongly, to never port these subs. The titaniums do well ported from what I've read, but not the Aluminum 88150/88120/88100 do.
Username: Kenwa
Post Number: 251
I just bought an RE SX15 so i might be interested in your box. Why is it tuned so high though?
Username: Frkkevin
Post Number: 614
Its tuned high to compete in local SPL shows. If you bought the box all you would need to do is go get a small piece of MDF and extend the port. If your really interested I might see if I can extend the port. The only drawback to that is there will be a slight edge where it buts together but I can use a dremel and grind the end down and then fill it until its smooth. Its a sturdy box and you won't find one cheaper. I can take more pics if anyone needs but like I said, its tuned to 45hz without sub displacement for SPL competitions
Username: Frkkevin
Post Number: 623
^bump^ .. back to the box.. anyone interested?
