Speaker terminals
Username: Lowfront
Post Number: 148
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=41&Object Group_ID=400
someone please help me out here, which am I sopposed to get.
Same with these
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=41&Object Group_ID=401
thanks a lot
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2929
to go onto the end of your speaker wires that hook to the speakers, you will need the F-Disconnect of whatever gague wire you are using.
with the second link, the "fork" style ends, they are all pretty much the same. gold plated stuff is suppose to be a little better, but i doubt any difference could be noticed. and again, just use the ones that fit the size screws they will be used with and whatever gague wire they will go onto.
Stockbridge, GA USA
Post Number: 2930
and do note that not all speakers will use thoes type connections. some will use the fork style.
also, i personally don't even use the fork style if thats what something calls for. i just use the bare wire.
yeah, i'm cheap with certain things anyway :-)
Username: Lowfront
Post Number: 149
How am I sopposed to know what size im going to need to the speakers, and amps and such.
I mean ya I know what wire size I'm going to us, but I feel like i need to pretty much order every single size for each speaker wire to make sure I get one that fits.
Stockbridge, GA USA
Post Number: 2936
well, you can almost guess close to the size and it'll work.
