Riverview but straight...,
Florida righ...
United states
Post Number: 1 Registered: Sep-06
ok i have 2' 12in LEGACY 500 WATT SUBWOOFERs ModEL: LWF12X
with a 2CH 1000w Xplore XR-3972
ok thats what i have right now an my box is a bandpass box. but my questions are: i read tha manual of the back of tha amp book an it said that im only getting 85W X 2 @ 4OHMS! that is rediculous! lol Can i adjust something or bridge it some kind of way to get more watts? or does anyone know a amp that pushes out 500 X 2 @4OHM??? THATS 100$ OR UNDER?
Bro throw all those stuffs away!... why didn't you get kicker cvr or even pioneer ts 306c they're only 55$ each. if you have some money left sell those subs and get 2 pioneer ts 306c
Florida righ...
United states
Post Number: 4 Registered: Sep-06
i cant bridge my amp some kind of way 2 get more watts? or do i just need to get another amp? i need one that puts out 500 X 2 @4OHMS tho for 100$ or under or a lil over
Florida righ...
United states
Post Number: 5 Registered: Sep-06
lol i didnt know when i bought then i just was looking at the watts of the subs an the watts of the amp thats all but i know more about it now. so sell the subs an keep the amp?
you f*cked all your system... sorry bro... see if you can sell it to a little boy or something like that cuz your system is pretty bad... even for the money
Florida righ...
United states
Post Number: 8 Registered: Sep-06
i bought it like a few weeks ago an im just startin to realize that my system is way lower compared to everyone elses i hear out on the street. so i found this site an joined an now im tryna get some professional help so i wont f*ck up again. but can u help me sell that system then?
they are 250wRMS a piece. if you put double the RMS wattage to those subs(b/c they are a cheaper, unreliable brand) they would definitely overheat and blow.
if they give you 50$ you're fine hehe lol i'm joking but see if you can get at least 150$... maybe you can get them cuz they will look new/clean... i hope you get some money and we will make you a great budget system... you'll be happy.
so i woulnd't bother putting them in a ported enclosure, you would have to tune them too high(hence the bandpass box they are in now) and you would blow them from playing below tuning.
your best bet to use those....is to put them in a sealed box. and not run any more than 250wRMS to them.
if i were you, i would sell those babies!!!
you won't get much for them, b/c they retail for $45 a piece.
Florida righ...
United states
Post Number: 14 Registered: Sep-06
lol ill see. but ya'll finish leavin ya'll opinons an sh*t ill read it when i wake up i never went 2 sleep since yesterday. but i need a new system ASAP! lol
if your budget is 200. i would go with a single sub, and an amp to push it. try looking at a cvr 15 or type r 15 and a A8002V on ebay. that will come out right around that.
^ I---the subs will unload when they start to play below tuning,and will bottom out eventually harming the VC or throwing it out of alignment......3308 posts and you don't know that yet?? lol
Brandon if you are in riverview im just right outside of Tampa I have diamond d3 400.4 that will push 200 x 2 Diamond Audio is high quality audio equipment. Im only about an hour away from you. I can sell it to you for $120.00 Dan 727 459 1623
