Distorsion
Username: Dandandan
Brisbane, Queensland Australia
Post Number: 162
just say you hav a sub thats 500 rms and you give it 300 and it distorts if you give it another 200 rms will it sound better without much distorsion
Username: Dandandan
Post Number: 163
oh yer and if you have an 25 rms amp and hook a 300 watt amp to it will that increase the 25rms to 325 rms or just make the 25 rms amp clip
Username: Stnorris
IA US
Post Number: 1224
if u have a 500rms sub, and it clips with 300rms, then something is set way wrong. clipping is when ur gain or something else is set wrong and u send the wrong kind of current to your sub....which clips it.
Username: Basshead86
Google is your Friend, FL
Post Number: 5117
do not link a 300wRMS amp and a 25RMS amp.
the ONLY amps you are supposed to link are ones that are designed to be done to, and they must be the exact same amp.:-)
Pine hill, Nj US
Post Number: 235
Who makes 25w rms amps anymore? Upload
Username: Illuminator
Post Number: 4728
External factory amps are about that wattage-rating, pieces of junk haha
Post Number: 5156
seriously. lol
