Ported box Q??
Username: Hockeyknight
Post Number: 225
i have a 12" soundstream refernce 600rms how big of a ported box should i build and what should i tune it to?? i want to get the most spl as i can outta it and someone recomended 2 ft cu at 35hz. would bigger be better?? if so what specs> thanks a ton!!!
Post Number: 226
oh and for the box would u recomend liquid nail or gorilla glue??
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 643
liquid nails
bigger box usually equals lower bass.
for sq and low bass, 28-32hz
for sql bass, 32-35hz
for spl and loud bass, 35hz+
Username: Riskyb
Post Number: 137
Liquid nail, it's cheaper and easily applied.
Using gorilla glue is over the top and uneeded because you would need alot to get a good seal and the bond liquid nails will form will still hold stronger than the mdf its attached to.
Post Number: 227
so like how would bout 4 cu ft tuned at 35 be with this sub?? oh and what should i do for bracing? thanks fer the help this is my first box.
Post Number: 229
oh and slot or tube ported??
Username: Stnorris
IA US
Post Number: 1220
i would go slot. you dont have to worry about port area, and slot is easier to do.
4 cu feet is way too big. i used to have 2 12s in a 4 cu feet box, and now i have 1 15 treo ssi in a 3 cu feet box.
i would say do look at the recommended box sizes for that sub on there site, or do a box like 2 - 2.5 cu feet...somewhere in there, and tune it to 35. 33 or 34 if u want a little more sound quality.
you dont need any bracing.
Username: Basshead86
Google is your Friend, FL
Post Number: 5115
i would email Soundstream. i am SURE they know. lol
or at least they could give you a range of box sizes it is suitable for.:-)
