One voice coil for now?
Username: Swisher
Marianna, FL
Post Number: 262
would it hurt if i only used one vc until i get my other amp?
Los Angeles, CA USA
Post Number: 4963
you mean use only on vc on a dual vc sub? don't do that.
Username: Swisher
Marianna, FL
Post Number: 265
damnit them ima have to wire it to 2 ohms cuz its a dual 1
Username: Adddisorder
West palm, Florida
Post Number: 637
yeah thats bad if you only use one
Username: Eggrollbandit05
what does a jumper do?
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 496
dont do that
Username: Baseball1187
Columbia, SC
Post Number: 709
yall are crazy... using one VC is fine
with that being said... do not put the combined RMS of both coils on one.
a lot of people use one voice coil and then do various other things to the second (leave it open, short it) to change the QTS of the sub. This was the idea behind the AA sub (the model slips my mind)... it was nothing new, just a little different spin on the idea
Username: Illuminator
Post Number: 4494
The above poster actually gave some insight as to why it should not be done.
It changes the parameters of the enclosure you need to put it in, a.k.a. you probably will ruin it because the box has an extremely high chance of being too big or too small.
Username: Rovin
Trinidad & T...
Post Number: 8905
question 4 all who r wondering about it >
if ur engine is a 4 cylinder ,would u only connect the electrical to 2 cylinders only !?
well hooking up 1 coil is like doing that IMO .......
Username: James1115
Ct
Post Number: 6418
A common misconception with regard to dual voice coil speakers is the assumption that nothing changes if you power only one of the voice coils. With only one coil hooked up, a dual voice coil speaker will suffer a loss in reference efficiency of about 3dB (only half the coil windings are being energized) as well as a significant shift in its Thiele/Small parameters. This renders any enclosure calculations inaccurate unless you remeasure the speakers parameters with only one coil hooked up. Failure to account for the different parameters of a dual voice coil speaker with only one coil powered can result in very poor performance.
Username: Rovin
Trinidad & T...
Post Number: 8906
now thats the detailed version ^^^ - lol .....
Username: Basshead86
Google is your Friend, FL
Post Number: 4777
i believe you could do something to the effect of changing the ohms on a Ava from 2 to 4 and it raised the efficieny of the driver....i dunno WTF i am trying to say....
Username: James1115
Ct
Post Number: 6427
on the atlas you could change the qts ofthe sub, but the second VC used was not te same as the first. Thats what make teh Atlas different then a normal dual VC sub
Username: Swisher
Marianna, FL
Post Number: 271
its ok i wired it to 2 ohms and its gettin a healthy 1500rms
Post Number: 4798
James straightened it out for me. lol
Username: Matt_stu
Post Number: 55
hmm this thread made me wonder if i wired my arsenal wrong. i have the speaker wire hooked up to the right terminal and nothing hooked up to the left one. the sub is 2 ohms and the amp is putting out 750w at 2 ohms. is my sub hooked up right?
Username: Matt_stu
Post Number: 57
im thinking should i have it hooked up like the top right sub http://mobile.jlaudio.com/support_pages.php?page_id=161
because right now i only have wire going to one of the terminals and nothing to the other. would it be best for me to hook it up + to + and - to- like the diagram. thanks all for the help
Username: Matt_stu
Post Number: 58
but the voice coil on the sub is dvc 4 ohms http://www.ascendantaudio.com/arsenal15specs.html
im new to the audio spectrum and im still trying to figure stuff out sorry for all the post thanks for any help
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 489
correct, you should wire it like in the top right picture. then you would have the vc's in parallel and give you a single 2 ohm load for that amp. you should be pleased with the results when done, if you havent already messed up the driver from only having one voice coil hooked up.
Username: Rob_preg
Post Number: 490
IMPORTANT NOTE! EVERYONE, QUIT WINGING IT WHEN HOOKING UP SUBS. IF YOU DONT KNOW EXACTLY WHAT YOU'RE DOING, GET HELP. QUIT ATTACHING SOME WIRES TO SOME TERMINALS AND HOPING FOR THE BEST! GOD!
Username: Rob_preg
Post Number: 491
i felt caps were justified
Username: Matt_stu
Post Number: 61
thanx for the help and im glad i read this thread before i did do some damage to it. glad i havnt been playing it that long or that much. just out of curiosity what ohm load would my amp have been seeing with the sub hooked up that way?
Username: James1115
Ct
Post Number: 6435
hooked up like the top right it would be a 1 ohm load.
