Big three?????
Username: Oglejust
Post Number: 63
ok, i have no idea what the big three is!!! can someone explain?
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1818
upgrade your electrical cables to a bigger gauge.
its batterie negative to ground,
alternator positive to batterie
alternator to the ground
Username: Oglejust
Post Number: 64
what does that help???
Username: Illuminator
Post Number: 4508
Mostly nothing unless your existing wiring is too small, or deteriorating.
It's mostly done when one upgrades to a high output alternator.
Username: Frkkevin
Lake Worth, Texas US
Post Number: 466
well i did not meter my voltage before i did it but i did the big three with 1/0 gauge stock alternator and a yellow top.. at 2000rmp im seeing 14volts but as far as getting louder it did nothing. my lights still dim as well so when i get extra money ill have to upgrade alts
Username: Swisher
Marianna, FL
Post Number: 268
https://www.ecoustics.com/electronics/forum/car-audio/214946.html
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 664
thought it was battery - 2 ground an alt.+ 2 battery + an ground from engine block? is there a ground on the alt. 2? an is it ok 2 have the engine ground right on the engine? 2 the battery ground cause i got it all moslty done just gota proplem gettin a bolt 4 a ground lol
