Which sub is best ?
Username: Cartel
Which will get me loud and ridiculously low without compromising sq?
2 3512
2 ssx12
2 rl-s 12
2 xxx 12
2 dreadnauts12
2 cvx 12
$ is not an issue, I m looking for the best.... Inputs will be greatly appreciated!!
Username: James1115
Ct
Post Number: 6428
I would say the 3512's would be your best bet.
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 518
either 2 3512 or the ssx's is what i go with
Username: Cartel
What's the rms? how much should i put to each sub for optimum performance...
Username: Basshead86
Google is your Friend, FL
Post Number: 4810
the 3500's do well with 1.5-2kw
the SSX's will do well with 2-3kw
Username: Cartel
is the values above per sub?
Which amp(s) do u recommend?
Username: Cartel
since it seems like the treo and dd are comparable, which pair will requre a smaller ported box space?
Username: James1115
Ct
Post Number: 6430
I am sure they are prob pretty comparable. Go to their websites and check them out.
