Problem With My Speakers...
Username: Sean119757
I'm having a problem with my speakers... ever since I had a Pioneer receiver deck installed in my car the front left tweeter sometimes goes out temporarily. I read somewhere that this happens when the speakers starts to go bad, but it never happened before I installed the cd deck. How can I fix this problem? Thanks.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2644
more details on the speakers you are having problems with?? what HU?? how are the speakers being powered??
either a wireing problem or a protection device for the speakers.
Username: Udalix
Manitoba Canada
Post Number: 12
If your using crossovers and an amp, just check to see if the wire is starting to come out of the crossover... Ive had this happen before, it would cut out once and awhile, just tightened it up and it was good, just a thought
