Ok....clippin maybe or??
Username: Halter
Paulding, Ohio
Post Number: 222
if my motors rpms are higher I can turn it up louder but on stops its shuts off......I have a hifonics 1606D on stock datkota chargein units....what should i do..optima then new alt or what??.... whats going on!!
Username: Mendonmafia
Post Number: 147
New Alt
Post Number: 148
High output of course
Username: Basshead86
Google is your Friend, FL
Post Number: 4791
alt. then battery.
otherwise you will just continue to drain batteries.
Username: Swisher
Marianna, FL
Post Number: 274
get www.excessiveamperage.com
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1430
180+ amp alternator and a new starter battery.
