Need help picking new subsPLZ
Username: Snick
here are the choices: which ones are the LOUDEST and HIT the HARDEST
1 12'' kicker l7
1 10'' solo x
2 10'' kicker l7's
1 12'' orion h2
1 12'' Eclipse Titanium SW9122
1 15'' kicker l7
maby 1 12'' solo x
the car i have is a dakota so got to keep it kinda small. and which ever one i choose will be going into a ported box. i am looking for sumthin that is gonna sound good but get crazy loud. and be louder or hit harder then 2 12'' mtx 8500.
MOST of all i need sumthin that u will hear comin
Username: James1115
Ct
Post Number: 6281
12 solo x
15 L7
12 eclipse TI10 solo X
2-10L7's
1-12L7
H2
Username: Swisher
Marianna, FL
Post Number: 261
im puttin an apx 10 in my dakota im just waitin on the alt to come in so i can hook it up
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 489
12 solo x, 10 solo x, 15 L7 are my choices if u want spl go with that
Username: Snick
will i be able to hear the music if i have the stock speakers i have the st so the lowest speakers in the car.
reason i am askin is because right now with my 10 l5 i can only hear the music when its all the way up
thanx for the fast replies
Username: Snick
will i be able to hear my music with any of these, with the stock speakers. because i can barley hear it now unless i have it up all the way.
i have the st so its not the best speakers system
Username: James1115
Ct
Post Number: 6284
no you are going to have to upgrade your mid's and high's
Username: Snick
damn thats the problem i cant cuz its a lease.
what if i was to turn the gain down. and turn it up to show off
Username: James1115
Ct
Post Number: 6285
you can change out the speakers in a lease just keep the stock's so you can replace them when you return the car. Are you gonna run off the stock Head unit?
Username: Snick
yes, and i am turnin it in in like 5 onths anyways so i dont think it would be worth it.
but would the option above work
thanx i kinda a newbie
Username: James1115
Ct
Post Number: 6289
sure but your alternator wont have the power to power a amp that the solo X's need
Username: Snick
Post Number: 7
i was thinkin about gettin a cap and only doin like 1800 rms to a solox.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3144
For pure SPL bang for the buck...and decent listening...i would go w/ the 15L7. Not the best sounding sub on your list, but they can get loud w/ about 1000w.
That would be your easiest choice.
also, if you already have those 8500 12's you may wanna just build a nice ported box for them. you could get them louder than you might think.
Username: Snick
Post Number: 9
my friend has them and i want sumthin louder.
he has space for them in a charger in dont cuz i got a truck so i am lookin for a one big or 2 small system. to take his out
Username: Basshead86
Google is your Friend, FL
Post Number: 4698
15" L7 gets my vote, b/cyour alt. won't be able to power the other correctly.
Username: Snick
Post Number: 11
would i be able to hear my music with a 15l7.
or would i have to turn the gain down
Username: Snick
Post Number: 12
or would i have to turn my gain down
Username: Snick
Post Number: 13
bump..............
Username: James1115
Ct
Post Number: 6354
no you wont be able to hear your stock speakers, they would sound like doo doo brown not being x'ed over.
