Amp help
Username: Thumping_corsica
Saginaw, miUnitd states
Post Number: 21
first, are the strike amps by lightning audio good?
i have 1 powering 2 type r's (500rms each 4 ohm dvc's) and the amp is 600 by 1 at 4 ohms so would this be ok or what? thx
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 668
if its 600watts @ 4ohms u run each sub @ 8ohms then run both - an + 2geather an ull git a 4ohm load
Post Number: 22
wait... im confused... should i run both subs seperatley in parrell or should i run em series??
