ROVIN! Subwoofer Box help please!
Username: Bump05
Hesperia, CA USA
Post Number: 50
ok chauncy said for my 2 15"kicker l7's do 6.0 cubic feet and 38hz so do i double it? well i was at subwoofer tools so what do i put for:
woofer xmax? (whats the l7s xmax and do i double it since i got two? same for the next question
driver displacment?
and when it says height and length i put the biggest i can do which is 35L and 22H
Username: Rovin
Trinidad & T...
Post Number: 8884
im not on the ball on those subs but im sure he meant 6cuft for both subs
go 2 kickers site & get the T/S specs 4 it - u do not double the xmax when u enter it
yes - u enter what H & L u would like ur box 2 be , u have 2 paly around with different H & L combos 2 see which design will suit ur needs ....
b{by the way - no need 2 kepp making new threads cause we all read most of the current threads..}
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1247
heavy internal bracing will add more rigidity than doubling the wall thickness
Username: Mendonmafia
Post Number: 99
Hey im Mark S well i was then i changed my Display name but i really am Mark S
