Memphis amp
Username: Nickyp0219
Post Number: 98
can a memphis pr1000.1 be wired to 1 ohm stable and not heat up. (w/ 15 L7)
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 473
yea the amp will heat up but if u set it correctly and dont give it hell all the time it shouldnt get burning hot
Post Number: 100
dude iuno what to do, i think its wired at 4ohms right now, seems to be hitting pretty hard, but iuno if at 1ohm itll pound?
Post Number: 101
why does it get hot if its rated at 1000rms @ 1ohm??
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1860
cuz not all the amps are 100% efficient so some part of the power dissipates in heat... and many other reasons
Post Number: 103
so is that bad or is my amp going to be able to last a long time?
Post Number: 477
if u set it right it will hold for a lilwhile but just dont give it hell but it will get warm
Username: Ctmike
Ct.
Post Number: 1344
your amp will be able to last longer than a little while.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3059
those are nice amps, so it should stay around for a while.
you cant just wire it to 1 ohm, because if ur sub is rated at 500 rms, and you wire it too 1 ohm (1000 @ 1) you will blow your sub, aka it wil make it pound for a half an hour or hour
Username: Juliob
Post Number: 1873
bassman WTF hehe, a 15 l7 is 1000w rms, i guess he owns the dual 2 ohm version, you're going to be fine if that's what you mean and the memphis will last if you know how to control de gain.
I bet you have a warranty right?
Post Number: 105
do you get a warrranty off of woofersetc.com, cause thats where i got it.
Username: Ctmike
Ct.
Post Number: 1347
not from memphis, check the website to see what kind of warranty they give.
Post Number: 106
yea they offer a full one year warranty on every product on their site
Post Number: 481
yea memphis is good if u send it back i sent back my memphis 1100 about a month ago they just sent me a brand new one
Post Number: 107
what was wrong with it?
Username: Juliob
Post Number: 1882
he f-ck it up messing with a sub hahahhaha!
Post Number: 482
no i just turned up the level all the way and the sub just went BOOM lol
